Raxman Posted April 9, 2014 Share Posted April 9, 2014 I find the stock tires on my 2014 legacy 2.5i convenience package, transmit every road surface imperfection and produces a hum at highway speeds . I also spotted the same tires on a new Sentra! Anyone upgrade stock tires for a more comfortable and quiet ride and what brand and model did you use? I have the 17in cast rims. Thanks Link to comment Share on other sites More sharing options...
krzyss Posted April 9, 2014 Share Posted April 9, 2014 What is the tire size? Krzys PS If Sentra has the same brand and model of the tire like your Legacy it means nothing, except that it was made by the same company. OE tires are made for car manufacturer specification. Link to comment Share on other sites More sharing options...
Raxman Posted April 9, 2014 Author Share Posted April 9, 2014 Tires: 215/50 R17 90V Bridgestone® Turanza™ EL400 All-Season Would a higher sidewall help perhaps? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
krzyss Posted April 11, 2014 Share Posted April 11, 2014 Perheps yes but you may have clearance issues, odometer and speedometer accuracy. Go to tirerack.com and look for Grand Touring AS (if you want all season tires) in your size. Check Consumer Report Nov issue at the local library too. Do you care about anything else except noice? Wet, snow, ice? Krzys Link to comment Share on other sites More sharing options...
Raxman Posted April 14, 2014 Author Share Posted April 14, 2014 I would use winter tires and steel rims - 16 in, november to april, and the 17in all seasons the rest of the year. I believe you can safely go up 10 percent in size, lets say to a 215 55 R17 AS tire. Not sure if this would make any difference in ride quality? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
outahere Posted April 14, 2014 Share Posted April 14, 2014 Tires: 215/50 R17 90V Bridgestone® Turanza™ EL400 All-Season Would a higher sidewall help perhaps?…………... Sometimes going smaller, e.g. down to a 16" wheel with a /55 or /60 tire, can help with the ride. But not always. CR did a 1" downsize on a Toyota Avalon, and did not get a significant ride improvement. Link to comment Share on other sites More sharing options...
krzyss Posted April 15, 2014 Share Posted April 15, 2014 If you want comfort look for comfortable tires (CR is good source for this info). You will much better gain from changing tire model/brand than from changing tire size on the same rim. Another option, if comfort is most important, run 16" year round. I think rule of thumb is +-3% of whole diameter. Krzys Link to comment Share on other sites More sharing options...
