motorbykemike Posted March 1, 2011 Share Posted March 1, 2011 car is 05lgt 5eat , has 97k on it , vf52 , dw740cc inj , perrin tmic , kb pickup , perrin lwcp , gfb reponz hybrid in 100% recirc , greddy up w/ egt , cobb ap on base 91 oct e-tune for those mods , stock airbox , stock catback (please no boost creep). turbo blanket will go as soon as it gets here (thanx msprank) , motor is sound . i am in eastern pa . just installed a perrin 2 pc , 2 catted dp & got cel/cruise flash , checked/cleared w/ ap , came back next day after some highwayish drive . cleared it again & have been reading all i can find here & on nasioc for the past 9 hrs. i know i need a retune for this addition , spoke w/ the tuner about the fact that my stock cats might not be 100% & i might go dp , they were ok but here i am w/ this dp anyways . Q#1 : ok i know i can just have the tuner "fix" it w/ the ap/tune but my question is will the car pass obdII ? i know the dash will not light up but will the code still be in the ecu making it "not ready" for obdII testing ? i assume the code came up because of the difference in cat material , size , density & such , tight stock cat matrix vs looser high flow perrin stuff . i'm cool w/ that . mpg has gone down from 35 to 33 but this is short term , less than 150 mi so i can not be hypercritical of this aspect yet . alignment is probably be off as well , killing mpg . Q#2 : i am aware that some peeps use the spark plug antifouler thingies as a mechanical fix but i am under the impression that the lgt's use the second 02 sensor to adjust fuel trims so i don't think i want to do that as that 02 sensor will not be seeing the "real world" . is this correct , the fuel trim part? Q#3 : how do i set up my ap beforehand w/ all the parameters i want to datalog so when i am in car i just press "log" instead of selecting all the items seperately in car while driving ? thanx in advance Link to comment Share on other sites More sharing options...
NSFW Posted March 1, 2011 Share Posted March 1, 2011 Yes you will still pass inspection. Don't mess with the rear O2 sensor. Dunno about the AP setup, I don't own one... Link to comment Share on other sites More sharing options...
