PearlBlueGT Posted November 23, 2012 Share Posted November 23, 2012 I bought engine cover for our 05LGT, what holds it on the engine? I need to buy some hardware. Link to comment Share on other sites More sharing options...
EJ25subie05 Posted November 23, 2012 Share Posted November 23, 2012 any push clips for those size holes will work. you'll need four of them. i use whatever i find in the shop Link to comment Share on other sites More sharing options...
TheBlackPearl Posted November 23, 2012 Share Posted November 23, 2012 Small world, I planned on making a run to Cyclebarn today to pick up some push rivets for mine, haha. Self proclaimed PNW Craiglist find of the day Champion, April 2014. Link to comment Share on other sites More sharing options...
EJ25subie05 Posted November 23, 2012 Share Posted November 23, 2012 yeah just use whatever works to keep the cover in place. its not that big of a deal... so you get an idea of what works, those push clips (idk what there called) that hold your hood heat shield in place, those work as well (at least i believe they are the right size) i used that same style clip on my cover. personally i run without a cover (weight reduction jk i just think it looks better without it) Link to comment Share on other sites More sharing options...
ibr_adam09 Posted November 23, 2012 Share Posted November 23, 2012 I took two bolts and jb weld them onto the front bracket facing upside down through the hole. Then use two nuts to the secure the cover in place. Link to comment Share on other sites More sharing options...
PearlBlueGT Posted January 6, 2013 Author Share Posted January 6, 2013 what holds it on in front? Rear ones line up to the holes on the intercooler bracket. What about front ones, is there bracket that supposed to be there? Link to comment Share on other sites More sharing options...
ripemeat Posted January 6, 2013 Share Posted January 6, 2013 there's suppose to be an alternator bracket with the cover holes on it Link to comment Share on other sites More sharing options...
Max Capacity Posted January 7, 2013 Share Posted January 7, 2013 NAPA will have the correct poppit's 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted January 7, 2013 Moderators Share Posted January 7, 2013 yeah just use whatever works to keep the cover in place. its not that big of a deal... so you get an idea of what works, those push clips (idk what there called) that hold your hood heat shield in place, those work as well (at least i believe they are the right size) i used that same style clip on my cover. personally i run without a cover (weight reduction jk i just think it looks better without it) Are you running the stock TMIC? The engine cover provides a seal to force air through there, FYI. I'm sure you know that though! "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
PearlBlueGT Posted January 8, 2013 Author Share Posted January 8, 2013 anyone have pictures of bracket? Link to comment Share on other sites More sharing options...
apexi Posted January 8, 2013 Share Posted January 8, 2013 I'm not familiar with with the GT's, so someone correct me if I'm wrong.. But is the bracket I circled in red what he needs? If so, it looks like the part number for the bracket is 14094AA210. It looks like the driver side of the bracket is held in place by a long alternator bolt, and the passenger side of the bracket has a bolt going in from the top, seen above the power steering pulley. Can't find a part number for the bolt above the pulley. Picture borrowed from the thread below http://legacygt.com/forums/showthread.php/timing-belt-replacement-2-5t-106809.html Link to comment Share on other sites More sharing options...
apexi Posted January 16, 2013 Share Posted January 16, 2013 Any update pearlbluegt? Link to comment Share on other sites More sharing options...
PearlBlueGT Posted January 16, 2013 Author Share Posted January 16, 2013 Yes, that's the bracket I need. Link to comment Share on other sites More sharing options...
