Chadsc529 Posted January 18, 2008 Share Posted January 18, 2008 I am not quite sure where to have posted this, but I couldn't find this topic anywhere. If I have overlooked a previous topic on this please let me know. Ok, here goes. I am a fairly big guy, 6'2" 215lbs and am looking to buy an 07 LGT Spec.B However the problem I keep running into is that the position of the emergency brake keeps jabbing me in my right thigh no matter where I put the driver seat. Has anyone run into this problem? Is there a way to fix/move the E Brake so it's not in the way so bad. Anyone please help I really want to buy one of these, but that brake makes it so uncomfortable I am not sure if I could tolerate it on my hr. drive to work everyday. Thanks in advance for any thoughts/suggestions. Link to comment Share on other sites More sharing options...
BigInALegacy Posted January 19, 2008 Share Posted January 19, 2008 Maybe you can swap it for a smaller handled one somehow. I could see that being a possibility. I haven't personally ripped my interior apart, but someone else may be able to comment on how this may go. Link to comment Share on other sites More sharing options...
spongemonster Posted January 19, 2008 Share Posted January 19, 2008 As far as those two numbers go I've got five pounds on you. It may be useful to list inseam in case anyone else searches for this problem. I'd love to offer advice but I can't quite wrap my head around how your leg is hitting it without trying it in my own car. Link to comment Share on other sites More sharing options...
lilrabbit129 Posted January 19, 2008 Share Posted January 19, 2008 I'm somewhat similar, 6'2" ~250ish pounds and the emergency brake doesn't come near my thigh. I do find the seat a bit cramped, but nothing major. Link to comment Share on other sites More sharing options...
nm Posted January 19, 2008 Share Posted January 19, 2008 Disclaimer: The above is for a 05 LGT un-limited wagon (which has a different seat) I'm big than you (both measures) As for the ebrake, you just really need to adjust your seating position, slam the seat all the way back and lower the seat to the ground. Its still there and my leg rubs against it, but no "jab" Oh and stop keeping stuff in right front pockets. FWIW, I just drove 2500mi and it was fine. However, if you're serious, you need an extended test drive. If this is a new car, you should be able to get a dealer to allow you 24hrs once you explain the situation. Link to comment Share on other sites More sharing options...
a2cpc Posted January 19, 2008 Share Posted January 19, 2008 If you are talking about the brake handle that is positioned on the driver's side of the transmission tunnel, I have that problem also. I drive an '08 Impeza, but it has the same configuration, as I noticed when I did my test drives. I was wondering if it was bent a little toward the gear shift if it would pose any kind of safety hazard. It doesn't appear it would be in the way when making shifts. That might not be to hard to do. Link to comment Share on other sites More sharing options...
Scruit Posted January 19, 2008 Share Posted January 19, 2008 6'2", 225lbs. No problem with the ebrake. Link to comment Share on other sites More sharing options...
John M Posted January 19, 2008 Share Posted January 19, 2008 6' 2", 290 here. I have trouble fitting my size 15 1/2 shoes under the dash but have no issues in the seat fittment category. Link to comment Share on other sites More sharing options...
BigInALegacy Posted January 19, 2008 Share Posted January 19, 2008 to the feet under the dash! Only primarily with a couple pairs of shoes though. Link to comment Share on other sites More sharing options...
Chadsc529 Posted January 20, 2008 Author Share Posted January 20, 2008 Maybe I used the wrong word "jabbing", but it does rub into my thigh where as in my 95 Eclipse the E-Brake isn't even near where I sit. I guess its just one of those things you get used to as you adjust to a different car. Thanks everyone for the input on it and I will keep that in mind when I go test drive another one. Link to comment Share on other sites More sharing options...
jmfspecb Posted January 21, 2008 Share Posted January 21, 2008 Chad - I'm quite a bit smaller and have found the ergonomic decision to place the brake lever where it is stupid as well. I think it is a bit of an anamoly for a Japanese car. What I can tell you is that you get used to it and eventually it becomes a non-issue. Link to comment Share on other sites More sharing options...
Sephon Posted January 21, 2008 Share Posted January 21, 2008 Chad, I've got you by a couple inches and a couple pounds. I initially found the E-Brake handle to just be an annoyance in the outer thigh. You will find the right position in the seat and it will soon become a non-issue. -Sephon Link to comment Share on other sites More sharing options...
STG Posted January 21, 2008 Share Posted January 21, 2008 Ok, here goes. I am a fairly big guy, 6'2" 215lbs and am looking to buy an 07 LGT Spec.B However the problem I keep running into is that the position of the emergency brake keeps jabbing me in my right thigh no matter where I put the driver seat. I'm bigger and taller than you and the brake doesn't bother me. Maybe that's because I don't sit with my legs spread apart like a hooker in an Amsterdam red light district whore house window. Link to comment Share on other sites More sharing options...
GTS Jeff Posted February 1, 2008 Share Posted February 1, 2008 Threads like is why North America gets shitty ass seats in the Subarus. Everyone is complaining about the wide seats in the new STI, but this thread just shows how all you fatasses made it happen. Seriously. You guys are all clinically obese. Link to comment Share on other sites More sharing options...
spongemonster Posted February 1, 2008 Share Posted February 1, 2008 ^^ Hahahahaha kinda harsh but still amusing. So at 213 and 6'2" I'm clinically obese? Keep in mind muscle does, in fact, weigh more than fat. I forgot about this thread but I do recall trying to replicate the problem. Try driving with your seat further back and your legs straighter. Link to comment Share on other sites More sharing options...
