Diggerdan11 Posted November 16, 2012 Share Posted November 16, 2012 So last night I installed a set of DDM HID’s into my Subaru. The light output was amazing and I am really excited about them. Left HID, Right Stock http://i245.photobucket.com/albums/gg54/diggerdan11/2012-11-15_19-10-09_592.jpg Well I then tuned my headlights off so the DRL’s were on, and the lights flash really bad. I’m thinking about disabling the DRL’s or turning my fog lights to DRL’s I then went for a drive to check out the light output and see how much I needed to adjust my headlights. I drove around an thought it seemed dim, got back to my house and noticed that my passenger light was off . Turned the engine off and back on and the light came one, drove around a bit, got back shut off the engine and turned it back on and the driver light was off, turned it off and back on and the light works. I then proceeded to turn the car on and off multiple times and both lights seems to work fine. I did some reading on here and noticed that it seems like there are lots of issues with aftermarket HID’s on here. Having one light not come on sometimes seems to be very common issues. So what’s the deal with HID’s on our Subarus? I have had many DDM HID kits in the past with all my other vehicles and have never had any issues. Is it something to do with Subaru? Do you guys think a HID wiring harness might fix the intermediate working issue? What about the flashing when the DRL’s are on, is that normal? I have HID’s in the Lows, Highs, and Fogs in my Tahoe, Highs and Lows in my Silverado, I had HID’s in the Lows, and Fogs in my Pontiac G6. All of them are DDM kits and I have never had a single issue. Link to comment Share on other sites More sharing options...
Drift Motion Posted November 16, 2012 Share Posted November 16, 2012 I didn't read the whole thing carefully, but DDM is a cheap quality kit. Buy the kit from TheRetrofitSource. It's a lot more expensive, but it's a much better product You need to disable the DRL for it to run correctly Link to comment Share on other sites More sharing options...
underground000 Posted November 16, 2012 Share Posted November 16, 2012 seemed like you didnt read enough. you need a harness 5eat downshift rev match:) Powder coated wheels: completed:) Link to comment Share on other sites More sharing options...
PeterJMC Posted November 16, 2012 Share Posted November 16, 2012 Like Drift Motion stated, you need to disable the DRL. Once you disable the DRLs, the headlights might start to fully ignite properly. Link to comment Share on other sites More sharing options...
Diggerdan11 Posted November 16, 2012 Author Share Posted November 16, 2012 seemed like you didnt read enough. you need a harness Yeah I did not read until after i installed it. I figured it would be simple plug an play just like every other vehicle I have put HID's in. I just ordered a harness form Xenonsupply.com. I added the DRL capacitor which supposedly will stop the DRL's from flickering. Hopefully that helps. Link to comment Share on other sites More sharing options...
Burba88 Posted November 18, 2012 Share Posted November 18, 2012 i put hids in mine and just disabled the DRLs no problems KMT Tuned Link to comment Share on other sites More sharing options...
mwakgp Posted November 18, 2012 Share Posted November 18, 2012 I've always wanted HIDs but have just read too many horror stories. Link to comment Share on other sites More sharing options...
LegacyKid5 Posted November 18, 2012 Share Posted November 18, 2012 I recently took a set of DDM's out of my car for what sounds like a similar problem to yours. The flickering is due to HID's having an issue with the DRL's as others stated, it's something to do with the the power level of the light. I unplugged the DRL's and after taking the kit out I plugged the DRL's back in and they don't work.. Just waiting on my TRS kit now! Link to comment Share on other sites More sharing options...
Burba88 Posted November 18, 2012 Share Posted November 18, 2012 they are very easy to put in like i said only problem i had is i had to unplug DRLs after that perfectionnnnnn , go for it KMT Tuned Link to comment Share on other sites More sharing options...
JMLegacy Posted November 25, 2012 Share Posted November 25, 2012 HID is one of the simplest upgrades you can do to your car, and might I add that safety is increased. With HID, the main problem is the ballasts blowing. Remedy? Get real good DIGITAL ballast. Head on over to http://theretrofitsource.com and purchase a good kit of digital 35W ballast also visit HIDplanet.com and learn all you want. That forum helped me retrofit my civic headlight. I have no issues. The bulb generally outlasts the ballast, they don't blow, just color shift And oh, don't forget you need a relay harness, or make one yourself. If you are installing HID into the halogen projectors, it stands a chance of melting it. some bulbs are hotter than some, and DO NOT use 55W ballasts Link to comment Share on other sites More sharing options...
Diggerdan11 Posted November 26, 2012 Author Share Posted November 26, 2012 So this weekend I installed the Wiring harness and they work like a champ. The harness came with the DRL capacitor and now my DRL's no longer flicker. Link to comment Share on other sites More sharing options...
MiniStiGuy Posted December 2, 2012 Share Posted December 2, 2012 Great. Now follow the aiming guide and get them within DOT spec. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
