mightyS Posted August 30, 2013 Share Posted August 30, 2013 I have seen some dyno graphs from cars using BNR 16G turbos. How many RPMs should it take for a BNR 18G turbo to make full boost? My AP datalog shows I am at 6 psi at 3100 RPMs, then 19.8 at 4100 RPMs and holding 18.25 at 7000 RPMs. Is it normal to be at 4000 RPMs to make full boost on this turbo? Here are my supporting mods: BNR 18G turbo DW 850cc Injectors Sidefeed Walbro Fuel Pump AVO TMIC Crawford Ail/oil separator STi Uppipe Cobb catted Downpipe Borla Exhaust Grimmspeed EBCS Agency power crank pulley Exedy lightweight flywheel Link to comment Share on other sites More sharing options...
mightyS Posted August 30, 2013 Author Share Posted August 30, 2013 I think I found the answer to my own question after looking through the Bren Tuning database. My car with the 18G is making boost a little sooner than the car shown in red here.http://www.brentuning.com/dyno/graph.php?gb=0&hp=1&torque=1&boost=1&rpm=1&sl=1&sln=1&sat=0&cb=0&dgr=1&smm=0&sg=1&runid1=415&rgb1=000000255&runid2=363&rgb2=204000000 Link to comment Share on other sites More sharing options...
iNVAR Posted August 31, 2013 Share Posted August 31, 2013 Hm, interesting. Didn't realize the 18G's spool was that bad. I could've sworn I've seen it come up faster than that, around 3500. That's.... disappointing. Link to comment Share on other sites More sharing options...
BrandonspecB Posted September 1, 2013 Share Posted September 1, 2013 Yeah, not very impressive. I've never really been a fan of the 18g. My Td06H-20g hits 25 psi around there in 3rd gear. Link to comment Share on other sites More sharing options...
mightyS Posted September 2, 2013 Author Share Posted September 2, 2013 These readings are from using 93 gas. I assume if you are hitting 25 Psi, you are using E85. The 18G turbo hits hard at 4000 and keeps on pushing. I feel a large increase in acceleration going from 3000 to 4000. Link to comment Share on other sites More sharing options...
BrandonspecB Posted September 2, 2013 Share Posted September 2, 2013 I'm using meth injection. I was commenting on the dyno graph not your particular setup. Link to comment Share on other sites More sharing options...
ovr9000 Posted September 4, 2013 Share Posted September 4, 2013 Did you get the upgraded wastegate actuator from Bryan? I had the same kinda issues (late spool, low boost) with the stock wg on the 18g and we have pretty similar mods. After putting the car back together with the upgraded wg and doing some datalogging, peak boost went from 18.5 psi @ 4200 rpm to 22.9 psi @ 3700 rpm. Still need to get tuned for the extra boost, so the car isn't being driven, but it was nice to see that it can do way better Link to comment Share on other sites More sharing options...
mightyS Posted September 4, 2013 Author Share Posted September 4, 2013 I did get the upgraded wastegate actuator from Bryan. I checked my first datalog from the basemap. The basemap target boost was 19.5 psi. I hit 23 psi at 3760 RPMs. Then the car shut off the fuel pump to save itself. I was told to adjust the actuator arm. Then I was hitting 19 psi at 3900 and 21 psi at 4100. After 4 revisions, I am hitting 19.8 at 4100. Is there a way to hit full boost sooner without overboosting? Link to comment Share on other sites More sharing options...
BrandonspecB Posted September 5, 2013 Share Posted September 5, 2013 Auto or manual? What gear do you do your pulls in? What were the intake temps? Link to comment Share on other sites More sharing options...
mightyS Posted September 5, 2013 Author Share Posted September 5, 2013 I have the 5 speed manual. 2005 car. Third gear for the pulls from 2000 to 7000 rpms. I have the Cobb accessport for logging. The air temps were in the mid 80's. The tune is an etune from Infamous tuning. I have been on this tune and turbo for 27,000 miles. Link to comment Share on other sites More sharing options...
BrandonspecB Posted September 5, 2013 Share Posted September 5, 2013 Have you ever done a fourth gear pull to see how it spools? No exhaust or boost leaks? Did you talk with Infamous about it? Sounds like from your revisions spool was slowed down to prevent spikes and fuel cut. It's a very fine line with an ebcs to get max spool with no spikes. Link to comment Share on other sites More sharing options...
mightyS Posted September 5, 2013 Author Share Posted September 5, 2013 Nope, I have not done a 4th gear pull. That is difficult unless I am on a racetrack. No leaks. I have the AVO intercooler to throttle body tube. Everything is tight. I had a vacuum leak about a year ago but that was fixed. The engine acted crazy and reved and stalled when I had that leak. I was hitting 21 psi at 4200 rpms after the first revision. Then I was hitting 19.8 at 4100 on my final revision. Link to comment Share on other sites More sharing options...
BrandonspecB Posted September 5, 2013 Share Posted September 5, 2013 Then I guess all is in order. Link to comment Share on other sites More sharing options...
