Kevin03045 Posted August 1, 2011 Share Posted August 1, 2011 It seems the rear upper body leans way to far from one side to the other in corners & it doesn't have to be hard corners either what could this be? About a year ago I heard a metallic pop like a bolt snapping & i have had the issue since, this is how i was able to pursued the wife to allow all of the suspension mods you see below which happen to be dealer installed last month. The car feels very stable & handles the corners very well it just scares the crap out of me & I hear no noise its like i have bad springs & shocks please help i am going broke trying to find the cause:spin: Suspension Mods Dealer Installed Koni inserts Epic Springs SpecB TopHats WhiteLine Upper & Lower front control arm bushings. WhiteLine Roll Center Kit Rear trailing arm bushings just replaced. WhiteLine Front 24m ajustable swaybar WhiteLine Rear 20m ajustable swaybar AVO Rear swaybar Mount Reinforcement Brackets Kartboy Swaybar endlinks Whiteline Sway Bar Alloy Lateral Lock Kit Front & Rear Whiteline Steering Rack Bushing Kit WhiteLine Rear Upper Control Arm outer Bushing 18inch rims 215x40x18 proxies Thanks Link to comment Share on other sites More sharing options...
AZP Installs Posted August 1, 2011 Share Posted August 1, 2011 My guess is that the rear sway may be a little disproportionate to the front one. I always strive to get matching sways front and rear. -mike http://www.pbase.com/paisan/image/91072632.jpg http://www.pbase.com/paisan/image/133406601.jpg AIM: AZP Installs | E-mail: paisan@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Dealer "Race Tested, Enthusiast Approved!" Link to comment Share on other sites More sharing options...
Burock Posted August 1, 2011 Share Posted August 1, 2011 I agree with the AZP suggestion. Try moving up to a 23mm bar from Hotchkiss. Not sure if rears go any higher than 23mm. May also consider adding the rear strut tower bar as a 2nd step if the beefier rear sway doesn't do the job, but benefit/ price ratio is low with this mod. Link to comment Share on other sites More sharing options...
sheppo9 Posted August 1, 2011 Share Posted August 1, 2011 Set the front sway to soft and the rear sway to hard as opposed to spending (wasting?) more money. Link to comment Share on other sites More sharing options...
Kevin03045 Posted August 3, 2011 Author Share Posted August 3, 2011 I was under the impression the Front OEM bar is supposed to be larger than the rear. I already have the front bar on soft & the rear on stiff. This only happens when taking right hand corners the left rear drops way to far, almost like the body is not connected to the subframe. The right side drops but nowhere near how far the left drops. 4 months ago i had to replace the trailing arm bushings because they were shot. Any ideas why & i don't think this has to do with a sway bar issue this is something else that wasn't there with my OEM rear & front sway bars. Link to comment Share on other sites More sharing options...
AZP Installs Posted August 3, 2011 Share Posted August 3, 2011 Hmm, you need to get it up on a lift and have all the bolts checked. If 1 side is different than the other then something is up. Could be anything w/o looking or driving it, very difficult to diagnose. -mike http://www.pbase.com/paisan/image/91072632.jpg http://www.pbase.com/paisan/image/133406601.jpg AIM: AZP Installs | E-mail: paisan@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1(2971)| T-1 Certified Amsoil Direct Dealer "Race Tested, Enthusiast Approved!" Link to comment Share on other sites More sharing options...
Kevin03045 Posted August 9, 2011 Author Share Posted August 9, 2011 update bolts are solid no visible issues. I am going to start replacing bushings any ideas on which to start with? My trailing arm bushings have already been replaced. Link to comment Share on other sites More sharing options...
