rapture Posted April 8, 2011 Share Posted April 8, 2011 so now i have a code and not sure how major this is...can someone help me with this one.....says P2016 intake manifold runner (i think position )sensor bank 1 Link to comment Share on other sites More sharing options...
rapture Posted April 8, 2011 Author Share Posted April 8, 2011 anyone?? Link to comment Share on other sites More sharing options...
BAC5.2 Posted April 8, 2011 Share Posted April 8, 2011 The P2016 is the TGV code for the passenger side. It's probably a sensor failure, and almost definitely unrelated to the AOS. I am fairly certain you can replace that sensor without pulling everything apart, and the part number should be 14120aa050. You could take it to a dealership, or anyone who has a SSM and have them verify that the issue is just the sensor. I bet you'd pay ~$330 for diagnosis and replacement. Or you could just go to the dealer and have them diagnose the problem. Most charge ~$99 to give you an answer. Then you can order the part and replace it yourself, or take it to an independent shop and have them do it for less. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
rapture Posted April 8, 2011 Author Share Posted April 8, 2011 thanks so much ..yeah i will def. NOT be taking it to the stealership i already learned they suck. i need to clean my throttle body anyay so i'l just replace it with my mechanic .is it really important tho? it doesn't seem to be effecting anything... Link to comment Share on other sites More sharing options...
BAC5.2 Posted April 8, 2011 Share Posted April 8, 2011 It's important enough to turn on the light, so it's important enough to fix. I only suggest the dealer because they have an SSM and can tell you with certainty if it's a sensor error or something else. If your mechanic has an SSM, then he can do the same thing. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
Max Capacity Posted April 8, 2011 Share Posted April 8, 2011 I would hope that most machanic's have access to the SSM or some other Pro series manual's. I know my guy goes on-line and get's the answers to anything he doesn't know. He's been around for a very long time. I trust him. I guess you already know that places like Advance Auto Parts will tell you the code for free. They also have a on-line site that can help you fix the problem and tell you how to replace the part. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
BAC5.2 Posted April 8, 2011 Share Posted April 8, 2011 I would hope that most machanic's have access to the SSM or some other Pro series manual's. I know my guy goes on-line and get's the answers to anything he doesn't know. He's been around for a very long time. I trust him. I guess you already know that places like Advance Auto Parts will tell you the code for free. They also have a on-line site that can help you fix the problem and tell you how to replace the part. SSM is the Subaru Select Monitor. You can watch the action of the sensor and verify sensor or physical failure. The STIS is the Subaru Technical Information System that houses the FSM refrences and other guides. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
Max Capacity Posted April 8, 2011 Share Posted April 8, 2011 Sorry, I "ass"umed it was a Shop Service manual. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
BAC5.2 Posted April 8, 2011 Share Posted April 8, 2011 No worries! [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
rapture Posted April 8, 2011 Author Share Posted April 8, 2011 yeah my car was acting real weird today, like wanting to stall at idle and kinda stuttering til around 2000rpms.gotta be related cause then it popped that same cel again after i cleared it with my ap. Link to comment Share on other sites More sharing options...
rapture Posted April 8, 2011 Author Share Posted April 8, 2011 question: if i do the tgv deletes myself will that then make this code not matter. or will it still pop after they are gutted. talked to fbp and it seems like it could be that a sensor was left disconnected ? Link to comment Share on other sites More sharing options...
ehsnils Posted April 9, 2011 Share Posted April 9, 2011 Depends on how you do the TGV delete. Some removes the butterflies and keeps the shaft, that way the motor and sensor is still connected. But be aware that the sensor is mounted with some "pre-tension", so if you remount it without then you will get a code. Link to comment Share on other sites More sharing options...
rapture Posted April 9, 2011 Author Share Posted April 9, 2011 ok, thanks ehsnils. so just gut them and get rid of the sensors seem the easiest route. then i don't have to go pay the stealership for a sensor i don't need ? am i right? Link to comment Share on other sites More sharing options...
ehsnils Posted April 9, 2011 Share Posted April 9, 2011 If you remove the sensors you need a different software that doesn't check the sensors, so the easiest way is to rig the sensors one way or another. Search for TGV Delete and you will find more than you want to know. Link to comment Share on other sites More sharing options...
rapture Posted April 9, 2011 Author Share Posted April 9, 2011 thanks i will...so is there a way to just complete the circuit till i gut the tgv's? also if i just gut the tgv's and take off these sensors will i need to get on the dyno again.? Link to comment Share on other sites More sharing options...
ehsnils Posted April 10, 2011 Share Posted April 10, 2011 Only way that is reliable is to make sure the sensors are OK. And if you get a CEL due to bad sensor you will probably fail inspection. Link to comment Share on other sites More sharing options...
rapture Posted April 10, 2011 Author Share Posted April 10, 2011 inspection is not a concern . just tryin to figure out the best way to solve this. Link to comment Share on other sites More sharing options...
ehsnils Posted April 10, 2011 Share Posted April 10, 2011 A sensor is about $110 according to this page: http://www.fastwrx.com/suoemtgse.html Your price should be in that area. See this thread over at NASIOC about TGV deletes, it may contain all you need to know: http://forums.nasioc.com/forums/showthread.php?t=1663677 Link to comment Share on other sites More sharing options...
rapture Posted April 10, 2011 Author Share Posted April 10, 2011 so lets assume i do this mod with my mechanic . i am currently at 288awhp and 347 at flywheel stock turbo, avo fuel pump,stock injectors. will i really need a tune afterwards ?. if so will i be able to drive to my dyno guy who is aprox. an hour away? or can i just get rid of the cels with my ap? Link to comment Share on other sites More sharing options...
BAC5.2 Posted April 10, 2011 Share Posted April 10, 2011 No. Once you touch the throttle, the TGV's open and stay open until you shut the car off again. You shouldn't need a tune. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
rapture Posted April 10, 2011 Author Share Posted April 10, 2011 no i was talking about deletes not the sensor.....after the tgv delete will i need a tune? or can i shut off codes with my ap? Link to comment Share on other sites More sharing options...
BAC5.2 Posted April 10, 2011 Share Posted April 10, 2011 I know what you were talking about. My answer applies. In your car now, you touch the throttle and the TGV's open and stay open. When you delete the TGV's, it's no different than them being open all of the time (mostly. There is some difference, but nothing that requires a tune.) [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
rapture Posted April 10, 2011 Author Share Posted April 10, 2011 ok thanks . the forum over at nasioc was saying diff. that a bunch of codes would insue and throw the car into limp mode..my mechanic busted the one sensor rite near the turbo trying to fix an exhaust leak and now i'd rather just delete them then buy a new sensor...just wanted to make sure i know what im about to get into. any one else have any tips before i tackle this diy .project? Link to comment Share on other sites More sharing options...
Mark34 Posted April 12, 2011 Share Posted April 12, 2011 Is it possible you could have knocked something loose during the AOS install? You had to be in that area while disassembling the plastic vent tubes to hook up the new vent hose to the AOS. Link to comment Share on other sites More sharing options...
guitar72186 Posted April 12, 2011 Share Posted April 12, 2011 I may have some of the sensor lying around from numerous motor tear down. You are local to R/T tuning to. I will be over my garage sometime this week and I can check for you. You can literally have it if you want, I was going to scrap the whole intake manifold from a WRX I have. Link to comment Share on other sites More sharing options...
