Doogie29th Posted January 23, 2014 Share Posted January 23, 2014 has anyone ever got upgraded rear axles to replace spec b? Im looking for length and spline info for DDS. Any help would be great. Thanks Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted January 26, 2014 Share Posted January 26, 2014 Only 06 Spec.b rear axles will fit 05-09 LGT, because they are the same axles & R-160 rear diff. 07-09 Spec.b rear axles are different, because Subaru switch to the R180 rear diff. But still keep the stock LGT 5X100 wheel hub. So unless you're upgrading your rear diff to a R-180. Theirs no OEM upgrade. But a quick search, their is custom aftermarket high HP axle out there wrx & sti. I'm sure they can build you ones for your LGT. Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
Doogie29th Posted January 26, 2014 Author Share Posted January 26, 2014 Exactly I have r180 with 04 sti 6my and have broke rear axles already. Im looking for info like length and spline for dds to make custom axles. My fronts are sti no prob upgrading there. Link to comment Share on other sites More sharing options...
Max Capacity Posted January 29, 2014 Share Posted January 29, 2014 PM Mike, HAMMERDOWN, he may have info for you, he's good with this stuff. Not many break the axles. Hey, go buy a Spec B axle from the auto parts store, measure it, then return it. Frank and Leigh are good guy's. Helped us out with our civic years ago. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted January 29, 2014 Share Posted January 29, 2014 PM Mike, HAMMERDOWN, he may have info for you, he's good with this stuff. Not many break the axles. Hey, go buy a Spec B axle from the auto parts store, measure it, then return it. Frank and Leigh are good guy's. Helped us out with our civic years ago. Can only by 07-09 Spec B Rear axle from Subaru Dealer. Copy/paste from other post; FYI on 07-09 Spec.B axle owners. I talk to a friend that's part owner of a NAPA store. He called his supplier, They have the axle, but Subaru as not released them to the aftermarket. So they can't sell them to us. You have to go through Subaru. But if you own a pair, Napa can send them in to get re-manufactured. That what I was told. This above is why you won't find any aftermarket 07-09 Spec.B Rear axle. If you still have your broken axles, you should be able to get all the info you need from them. Mike Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
Doogie29th Posted January 30, 2014 Author Share Posted January 30, 2014 Thanks guys I talked with Driveshaft shop. Im shipping them a broken axle to see what they can do to make an upgraded pair. I need something that will hold 750ish whp..... Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted January 30, 2014 Moderators Share Posted January 30, 2014 Thanks guys I talked with Driveshaft shop. Im shipping them a broken axle to see what they can do to make an upgraded pair. I need something that will hold 750ish whp..... Subscribed "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
boxkita Posted January 30, 2014 Share Posted January 30, 2014 didn't nsfw get custom axles from driveshaft shop for his 6mt swap? Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted January 30, 2014 Share Posted January 30, 2014 didn't nsfw get custom axles from driveshaft shop for his 6mt swap? No, drive shaft, same place who made mine. http://i193.photobucket.com/albums/z151/Legacy_NSFW/6MT/Shafts.jpg The small shaft is the OEM. The other is my new shaft. It was a little cheeper then OEM, but it 3x as stong & can be 100% rebuildable for pennys on the dollar. http://i99.photobucket.com/albums/l293/HAMMERDOWNGT/Subaru/th_0915070022.jpg http://i99.photobucket.com/albums/l293/HAMMERDOWNGT/Subaru/th_0915070017.jpg http://i99.photobucket.com/albums/l293/HAMMERDOWNGT/Subaru/th_0915070033a.jpg Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
Max Capacity Posted January 30, 2014 Share Posted January 30, 2014 FWIW, When it comes to big WHP Rob Moore Nitro Drivelines, made the axles, spool, hubs, and spindles when we were looking for the Honda B series. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Strizzy Posted March 13, 2014 Share Posted March 13, 2014 I have a spare specB rear axle and will be sending it to DSS this weekend. If anyone else would like to order a set of rear axles, let me know. We should be able to get a slight discount if there are multiple orders. My bad luck build Link to comment Share on other sites More sharing options...
Doogie29th Posted March 14, 2014 Author Share Posted March 14, 2014 Hold off sending your axle. They have one of mine. I have been working with Tad @ dds. I was just talking to him on the phone today. Link to comment Share on other sites More sharing options...
Strizzy Posted March 14, 2014 Share Posted March 14, 2014 I'm not sure who I was speaking with, but he said they never did anything for a specB. I have mine packed up and ready to ship (they gave me a RMA#). I will hold off though. I was also planning on sending them a front axle as well. My bad luck build Link to comment Share on other sites More sharing options...
bnguyenbb6 Posted March 16, 2014 Share Posted March 16, 2014 Keep us updated! I'll most likely need to upgrade soon. Link to comment Share on other sites More sharing options...
Doogie29th Posted March 19, 2014 Author Share Posted March 19, 2014 So dds does not make 25 spline axles. The option is to switch to wrx (24 spline) or sti (27 spline) hubs. Link to comment Share on other sites More sharing options...
whitetiger Posted March 19, 2014 Share Posted March 19, 2014 ^that swap cant be done easily as there is no solution for the rear hub. Link to comment Share on other sites More sharing options...
Doogie29th Posted March 19, 2014 Author Share Posted March 19, 2014 08+ wrx hubs would work. Link to comment Share on other sites More sharing options...
whitetiger Posted March 19, 2014 Share Posted March 19, 2014 only in the front, not in the rear. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted March 19, 2014 Moderators Share Posted March 19, 2014 only in the front, not in the rear. that's what she said. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
whitetiger Posted March 19, 2014 Share Posted March 19, 2014 *rimshot Link to comment Share on other sites More sharing options...
Doogie29th Posted March 19, 2014 Author Share Posted March 19, 2014 Whats the option for the rear hubs that will work? Link to comment Share on other sites More sharing options...
bettner12 Posted March 19, 2014 Share Posted March 19, 2014 So dds does not make 25 spline axles. The option is to switch to wrx (24 spline) or sti (27 spline) hubs. doesn't make? or wants to be lazy and not even try, trust me that can make whatever axle they want to. I talked to them about legacy axles a few years ago, and I see that nothing has changed... Link to comment Share on other sites More sharing options...
whitetiger Posted March 20, 2014 Share Posted March 20, 2014 Whats the option for the rear hubs that will work? this is none. we have a whole thread about people trying to get a sti 5x114.3 hub to work but no resolution yet. the 3rd/4th gen Legacy has a unique rear knuckle/trailing arm that is not shared with any other subaru platform. it would be easier to get an axle shop to make something custom than getting a cross platform hub swap Link to comment Share on other sites More sharing options...
Nightmaresmk Posted March 21, 2014 Share Posted March 21, 2014 THe hub swap would either require the rear sti suspension swapped in with a custom front drop arm. or machine the rear knuckles to accept it. Link to comment Share on other sites More sharing options...
bnguyenbb6 Posted March 21, 2014 Share Posted March 21, 2014 I just emailed raxles to see if they could do anything. I have another set of axles coming in so I can send one off if they need it. If that falls through, I'll look into machining wrx hubs to work. What was Subaru thinking though? Just make them the same lol Link to comment Share on other sites More sharing options...
