MAINIAC SPEC B Posted July 28, 2007 Share Posted July 28, 2007 Of all the mods done to the intake & exhaust systems it looks like the one that gets you the most benefit if you are doing only one for now is the Down pipe. My up pipe came catless. What say you? Link to comment Share on other sites More sharing options...
hondas123 Posted July 28, 2007 Share Posted July 28, 2007 Downpipe is the minimum you need to go to stage 2. - The Mortgage Man Link to comment Share on other sites More sharing options...
frathouse87 Posted July 30, 2007 Share Posted July 30, 2007 DO IT! Stage2 woo! Link to comment Share on other sites More sharing options...
Scooter Posted July 30, 2007 Share Posted July 30, 2007 Looks like someone actually read the 'Sticky' information, rather than just run out an purchase an intake and BOV! Congrats. Yes, a DP + Tune provides the biggest gains. Unfortunately, the 'tune' part is still an issue for you and your 2007 B. You can do the DP without the tune, but then you won't see the gains. Seek first to understand, then to be understood. In other words: SEARCH before you post! Link to comment Share on other sites More sharing options...
frathouse87 Posted July 30, 2007 Share Posted July 30, 2007 you'd see....some Link to comment Share on other sites More sharing options...
RdiggA Posted July 30, 2007 Share Posted July 30, 2007 there will be some, not much though, i just installed a Perrin 3" catless full length, a little more sound but not too much sounds basically stock with just a little more rumble. Maniac, if you put in a catless DP get some Spark plug spacers or anti foulers (same thing) and drill it out with 1/2" drill bit and you wont have a problme with a CEL. Link to comment Share on other sites More sharing options...
frathouse87 Posted July 31, 2007 Share Posted July 31, 2007 just get ECUtek and be done... Link to comment Share on other sites More sharing options...
scooby600 Posted August 1, 2007 Share Posted August 1, 2007 I installed a invidia 3" catless full length downpipe earlier this month and for a couple days I was getting like 27-29mpg from the 22-23 I was getting before and then the CEL came on. After the CEL came on, I got 23-24mpg so I did the spark plug thing to get rid of the CEL but I've already put 15 miles and the light is still on. Someone told me to take off the ground side of the battery and put it back on, so I tried that but it didn't do anything. Any ideas? Link to comment Share on other sites More sharing options...
frathouse87 Posted August 1, 2007 Share Posted August 1, 2007 disconnect neg batt terminal, push brake 5 times, connect and go Link to comment Share on other sites More sharing options...
