bizmackus Posted December 1, 2013 Share Posted December 1, 2013 Hey guys, I was underneath my 99 LGT wagon poking around and I noticed both of the rear sway bar links have a lot of side to side play. I can move them a good 1/4 inch to the right and left with no effort. Is this normal? Everything is stock. Thanks! Link to comment Share on other sites More sharing options...
spooln30 Posted December 2, 2013 Share Posted December 2, 2013 Replace them, they're cheap enough or even get upgraded ones. Also check the sway bar bushings, if the links are worn then probably the bushings are close to the same. Check the fronts too. Btw was the car jacked up or on the ground cuz if it was in the air they should be hard to move if at all. Link to comment Share on other sites More sharing options...
