ant Posted October 1, 2010 Share Posted October 1, 2010 its a 5spd and it is stuck in 2nd. the stick moves from left and right as if it was out of gear but wont back and forth. everything else works fine just stuck. any ideas and i could use a transmission diagram if anyone has one. thx Link to comment Share on other sites More sharing options...
Platinum_Racing Posted October 4, 2010 Share Posted October 4, 2010 So the stick moves side to side as though its in neutral, but it won't go in any other direction? I'd check the linkages first. Link to comment Share on other sites More sharing options...
subikid90 Posted October 5, 2010 Share Posted October 5, 2010 +1 on the linkage and fork -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
ant Posted October 8, 2010 Author Share Posted October 8, 2010 i checked the linkage its all fine. im thinking its the fork just need to know if i can take the back part off the tranny to get to it or have to drop the whole thing Link to comment Share on other sites More sharing options...
speezly Posted October 21, 2010 Share Posted October 21, 2010 did you try adjusting the clutch tension screw under the hood? i had this problem back in the day when i first got my legacy. it drove me nuts cause i couldnt figure it out but the screw worked Link to comment Share on other sites More sharing options...
