dylandevine123 Posted May 16, 2012 Share Posted May 16, 2012 I have a set of STi pink injectors laying around and was wondering if they would fit my 97 legacy gt 2.5? I am also looking to upgrade my fuel pump to compensate for the increase in injector size. Any comments and suggestions are welcome. Link to comment Share on other sites More sharing options...
SCASEYS Posted May 16, 2012 Share Posted May 16, 2012 so, your GT was swapped? I only assume because you are asking about changing your fueling. As far as I know (me=n00b) 2nd gens are NA I donated to LegacyGT.com which allows me to have this nifty signature. If anything SCASEYS posts ever becomes a sticky i'm gonna light this whole place on fire Link to comment Share on other sites More sharing options...
apexjapan Posted May 16, 2012 Share Posted May 16, 2012 Upgrade your injector size only if you are increasing hp, through engine build or force injection. Otherwise, you won't add any performance and will likely suffer a reduction in gas mileage. In addition, unless you can tune for it, the car doesn't know you have larger injectors and will continue to attempt to meter out fuel as if they were standard sized injectors. Won't be pretty. Regards, Paul Hansen http://www.avoturboworld.com http://www.facebook.com/avoturboworld Link to comment Share on other sites More sharing options...
dylandevine123 Posted May 17, 2012 Author Share Posted May 17, 2012 Thanks I was thinking that it was just going to be a bolt on hp gainer but th engine is NA so no gains and probably a drop in performance is not worht the time and effort to put them in thenks again!!! Link to comment Share on other sites More sharing options...
