mikesubie13 Posted February 20, 2014 Share Posted February 20, 2014 Trying to figure out if auto and mt trans use the same front axles ? Also if 2.5i and gt have the same front axles ? Thanks everyone Link to comment Share on other sites More sharing options...
heiche Posted February 20, 2014 Share Posted February 20, 2014 you could probably look up the axle part number for the various applications, and compare. http://opposedforces.com/parts/legacy/us_b13/type_7/ BtSsm - Android app/Bluetooth adapter. LV, logging, gauges and more. For 05-14 Legacy (GT, 2.5, 3.0, 3.6), 02-14 WRX, 04-14 STi, 04-14 FXT, 05-09 OBXT Link to comment Share on other sites More sharing options...
Max Capacity Posted February 20, 2014 Share Posted February 20, 2014 Might find something here too. http://legacygt.com/forums/showthread.php/idea-web-links-saved-various-parts-219238.html 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
frank_ster Posted February 27, 2014 Share Posted February 27, 2014 All the front axles are the same on 4 th gens Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
mikesubie13 Posted February 28, 2014 Author Share Posted February 28, 2014 Auto and manual the same ? Link to comment Share on other sites More sharing options...
frank_ster Posted February 28, 2014 Share Posted February 28, 2014 yes Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
mikesubie13 Posted May 1, 2014 Author Share Posted May 1, 2014 6spd spec b front axles the same as 5spd mt lgt axles ? Or they different ? Tried searching for a write up on what axles work with what transmissions couldn't find anything !! Link to comment Share on other sites More sharing options...
frank_ster Posted May 1, 2014 Share Posted May 1, 2014 yea 5 mt 5 eat and 6mt are the same axles.. older than 04 trans missions have removable male male stub shafts. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
Strizzy Posted May 1, 2014 Share Posted May 1, 2014 6spd spec b front axles the same as 5spd mt lgt axles ? Or they different ? Tried searching for a write up on what axles work with what transmissions couldn't find anything !! They are also the same as 08+ WRX front axles. My bad luck build Link to comment Share on other sites More sharing options...
mikesubie13 Posted May 2, 2014 Author Share Posted May 2, 2014 so for the most part any 5x100 front axle after 2004 will work correct me if i am wrong and thank you guys for the quick response Link to comment Share on other sites More sharing options...
Max Capacity Posted May 8, 2014 Share Posted May 8, 2014 so for the most part any 5x100 front axle after 2004 will work correct me if i am wrong and thank you guys for the quick response This guy would know. He's one of the go to guys here. yea 5 mt 5 eat and 6mt are the same axles.. older than 04 trans missions have removable male male stub shafts. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
