exclucid Posted September 21, 2011 Share Posted September 21, 2011 My fingers hurt and have multiple cuts. I read over and over recommendations to buy the uppipe, which can be had for less than 100 dollars, over attempting to gut the uppipe. It took more than twelve hours to remove the uppipe and down pipe and gut the uppipe. The first cat in the down pipe was easy comparatively. I left the second cat in the downipe. I was able to succesfully gut the uppipe, but if I was to do it over again, I would buy it every tim. Way too hard, I am happy to report this made made my 5eat noticebly quicker off the line. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 21, 2011 Share Posted September 21, 2011 You might as well gut the second cat in the DP and get the car tuned. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
JLB Posted September 21, 2011 Share Posted September 21, 2011 I do think you need a tune now unless you have an ap so be careful Link to comment Share on other sites More sharing options...
GTTuner Posted September 21, 2011 Share Posted September 21, 2011 The proper tool to break up the metal substrate inside the UP makes a big difference. I use an air hammer with a long curved chisel, break out the center and the sides fall right out. Leave the third cat in place, not much restriction there. I have done a few, the UP can be a PITA. Link to comment Share on other sites More sharing options...
exclucid Posted September 21, 2011 Author Share Posted September 21, 2011 Yeah just got a.cel for cat under threshold performance. Time for a tune.... Stage one recommendation for mile high Link to comment Share on other sites More sharing options...
