Markbo Posted April 22, 2015 Share Posted April 22, 2015 Dave at Cryotune is out of town this week so I cant ask him. Last week I was doing a log run in Romraider with Tactrix cable, watching dashboard LC-1, AFR & RPMs. LC1 data just died...all zeros. Finally git some time and had my laptop checked out just in case and all is well. Plugged it all up for a run this morning and LC1 #s seemed too low so did a heat and air recalibration. Hooked it all up again and they are still low. All rough numbets here - AFR is reading 14.5 idle and 11.8 getting on it. LC1 is reading 4.5 - 3.5 @ those times. Is this normal or is there something wrong with my LC1??? BTW I checked Lamda & other fuel readings and noticed the data is exactly the same if I choose diesel AFR or gasoline AFR Link to comment Share on other sites More sharing options...
spec.B Dream Posted April 22, 2015 Share Posted April 22, 2015 Sounds like another dead LC-1. I went through 3 of them before switching to PLX. Link to comment Share on other sites More sharing options...
rhino6303 Posted April 23, 2015 Share Posted April 23, 2015 My LC-1 sensor has died once but I knew it because my afr gauge would peg rich and flash. If resetting the sensor doesn't fix it I would probably agree the sensor is dead. Not too expensive on amazon. Search for bosch 17014. Link to comment Share on other sites More sharing options...
Markbo Posted April 23, 2015 Author Share Posted April 23, 2015 Why would the sensor die so quickly? Id be willing to bet it doesnt have 1000 mile on it Link to comment Share on other sites More sharing options...
rhino6303 Posted April 23, 2015 Share Posted April 23, 2015 Check the grounds. It shouldn't die that quickly. The wiring for the lc-1 is super picky! Link to comment Share on other sites More sharing options...
snm95ls Posted April 23, 2015 Share Posted April 23, 2015 Check the grounds. It shouldn't die that quickly. The wiring for the lc-1 is super picky! Truth about the wiring unless things have changed with the latest iteration. Link to comment Share on other sites More sharing options...
bnguyenbb6 Posted April 23, 2015 Share Posted April 23, 2015 The wiring is truly terrible. Its a big reason why I switched to an AEM, no more headaches of having a WB02 randomly go out. If it is a sensor, you should be able to find the sensor locally at Autozone. IIRC its the same sensor used for an Audi/VW. Link to comment Share on other sites More sharing options...
snm95ls Posted April 23, 2015 Share Posted April 23, 2015 I ran one daily for years. I have another that was used for tuning on multiple vehicles and has been permanently installed for various periods of time in about 4 differe t vehicles. Unless thi gs have changed, RTFM and you won't have massive issues related to wiring. The AEM is a much more "user friendly" unit, but the lack of flexibility can be a disadvantage depending on one's needs. Link to comment Share on other sites More sharing options...
Markbo Posted April 23, 2015 Author Share Posted April 23, 2015 RTFM...there is nothing in the manual about this particular issue. 8 or 10 other errors, but not this. ETA all wiring connections have been checked and rechecked. Link to comment Share on other sites More sharing options...
Streetlegal Posted April 23, 2015 Share Posted April 23, 2015 Get an MTX-L. It is the updated version where there is no separate control box. It is all in the gauge. I love mine. Not sure about the LC-1 but with the MTX-L it has analog wires also so you can run it in place of the factory wires instead of having to put another bung in and run it separate. Has a connection for data logging too so you wouldn't be losing that. Link to comment Share on other sites More sharing options...
whitrzac Posted April 23, 2015 Share Posted April 23, 2015 Get an MTX-L. It is the updated version where there is no separate control box. It is all in the gauge. I love mine. Not sure about the LC-1 but with the MTX-L it has analog wires also so you can run it in place of the factory wires instead of having to put another bung in and run it separate. Has a connection for data logging too so you wouldn't be losing that. The MTX-L is not the updated version... Its just for a simpler instal... The LC-2 is the updated version;) I have both, they both work. I would pick up another sensor at your local auto parts store and test that. Are you using the serial connection, or 0-5v analog to check afr? Link to comment Share on other sites More sharing options...
Streetlegal Posted April 23, 2015 Share Posted April 23, 2015 The MTX-L is not the updated version... Its just for a simpler instal... The LC-2 is the updated version;) I have both, they both work. I would pick up another sensor at your local auto parts store and test that. Are you using the serial connection, or 0-5v analog to check afr? Really? Hmm I thought it was. Oh well. Works great and I like it Link to comment Share on other sites More sharing options...
Markbo Posted April 23, 2015 Author Share Posted April 23, 2015 Whit - I am using the serial connection Link to comment Share on other sites More sharing options...
joeleodee Posted April 23, 2015 Share Posted April 23, 2015 If it is just the sensor, you'll be able to find the Bosch 17014 sensor at any auto parts store to replace. I've gone through at least 2 sensors before I took over the tuning on my vehicle. It was running too rich and fouling out the sensors. Ever since I took that over, I've had the same sensor for nearly 3 years permanently installed. I've recalibrated a few times over the years. Otherwise, my LC1 has been okay. Link to comment Share on other sites More sharing options...
rhino6303 Posted April 23, 2015 Share Posted April 23, 2015 One thing I had to do with my LC-1 is make a quick heatsink using a short section of copper pipe. Cut it lengthwise, flatten it and drill a hole in the center; lastly fold up the sides. Link to comment Share on other sites More sharing options...
Markbo Posted April 24, 2015 Author Share Posted April 24, 2015 And do what with your folded up piece of copper???? Link to comment Share on other sites More sharing options...
rhino6303 Posted April 24, 2015 Share Posted April 24, 2015 Place between sensor and exhaust pipe. Link to comment Share on other sites More sharing options...
Markbo Posted April 24, 2015 Author Share Posted April 24, 2015 Place between sensor and exhaust pipe. And what does that accomplish Rhino? Mine is mounted just 8-10" from the turbo. I'm sure it's getting plenty warm Link to comment Share on other sites More sharing options...
whitrzac Posted April 24, 2015 Share Posted April 24, 2015 It's a heat sink. The senor can overheat and die. http://www.innovatemotorsports.com/support/faq.php Link to comment Share on other sites More sharing options...
Markbo Posted April 28, 2015 Author Share Posted April 28, 2015 Ok...a little update. After 3 tries I finally got a return email from innovative motorsports and got some more guidance. Set up as usual log works reads the lc1 normally. At the same time Romraider is reading...nothing. The output voltage is lower than what IM said it should be (reading 0.111v & should be 4.0-4.5v) so I dont know if that would account for it. So all I know for certain is the sensor is working. But I dont know why Romraider cant read it. Link to comment Share on other sites More sharing options...
technicalgarage Posted May 18, 2015 Share Posted May 18, 2015 Open up lmprogrammer and make sure it didn't reset the fuel calibration to something else on its own. I've seen it happen sometimes if you remove the 2.5mm plug while the LC-1 is on. Link to comment Share on other sites More sharing options...
whitrzac Posted May 18, 2015 Share Posted May 18, 2015 Ok...a little update. After 3 tries I finally got a return email from innovative motorsports and got some more guidance. Set up as usual log works reads the lc1 normally. At the same time Romraider is reading...nothing. The output voltage is lower than what IM said it should be (reading 0.111v & should be 4.0-4.5v) so I dont know if that would account for it. So all I know for certain is the sensor is working. But I dont know why Romraider cant read it. If logworks is seeing the widband, you have a romraider issue. Is the com port setup correctly in romrader? Plugins -> inovate wideband -> com## You can not use romraider and logworks to view the Lc1 at the same time. Link to comment Share on other sites More sharing options...
Markbo Posted May 20, 2015 Author Share Posted May 20, 2015 I know they cant be used at the same time and I am 100% sure the com port is correct. At this point is it worth it to just uninstall romraider and reload it? Link to comment Share on other sites More sharing options...
rhino6303 Posted May 20, 2015 Share Posted May 20, 2015 One thing I had to do with romraider is delete all other plugins from loading and only allow the lc-1 to load. Also, be sure to load the lc-1 after romraider has connected to the ecu. The sequence should be to load romraider-->connect to ecu-->load lc-1 plug in. To delete other plugins browse to the romraider folder, find plugins and delete all but the lc-1. Link to comment Share on other sites More sharing options...
Markbo Posted May 25, 2015 Author Share Posted May 25, 2015 Welp, I changed out the O2 & have the same issue. LC-1 is reading way lower than the stock unit - which is in the correct range. Soooooo after getting my laptop serviced and the car checked out it HAS to be the LC-1 malfunctioning. I cannot test otherwise but I have no reason to believe it is Romraider since all othe parameters appear normal. I suppose at this point I have to replace it with an LC-2 unless anyone can recommend a different/better wideband scanner that works with Romraider. Open to any advice & suggestions. Link to comment Share on other sites More sharing options...
