Herda2448 Posted October 16, 2017 Share Posted October 16, 2017 I am hope that you guys could shed some light on the subject of doing your own fluid Flushes. Just got my car back from the dealer after finally getting the airbag recall done on the car. Of course they do the complimentary inspection and everything checked out just fine. But I they recommended some fluid Flushes of pretty much the entire system. Brake system flush, radiator flush, transmission fluid change, and changing spark plugs but that's a completely different topic for another day. My questions are, is it possible and economical for me to do these on my own? Is it worth spending the $350 quoted for the three systems to be changed out? Has anybody done these on there own? If so, how? Thanks in advance. Link to comment Share on other sites More sharing options...
GTEASER Posted October 16, 2017 Share Posted October 16, 2017 Yes, you can do those yourself, most of us here do. What model car do you have? And how many miles? GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
MilesA Posted October 16, 2017 Share Posted October 16, 2017 Follow the maintenance schedule called out in your owner's manual, that's all you have to do to keep your car in good shape and satisfy warranty requirements. Dealers are notorious for trying to add other services to justify padding the bill. They usually make more money on servicing cars than on selling them in the first place. Your maintenance schedule does not call for flushing anything with a special machine, for example. It calls for changing fluids, which means a simple drain and fill, that you can do at home with a few simple tools and supplies. Just make sure the fluids used meet the manufacture's spec. The CVT, if you have one, would be an exception. There is a specific procedure for that and maybe the shop would be better for that particular service. Link to comment Share on other sites More sharing options...
Herda2448 Posted October 16, 2017 Author Share Posted October 16, 2017 Yes, you can do those yourself, most of us here do. What model car do you have? And how many miles? I have a 2012 Legacy 6mt. There are just under 98k. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Herda2448 Posted October 16, 2017 Author Share Posted October 16, 2017 Follow the maintenance schedule called out in your owner's manual, that's all you have to do to keep your car in good shape and satisfy warranty requirements. Dealers are notorious for trying to add other services to justify padding the bill. They usually make more money on servicing cars than on selling them in the first place. Your maintenance schedule does not call for flushing anything with a special machine, for example. It calls for changing fluids, which means a simple drain and fill, that you can do at home with a few simple tools and supplies. Just make sure the fluids used meet the manufacture's spec. The CVT, if you have one, would be an exception. There is a specific procedure for that and maybe the shop would be better for that particular service. I agree with that Subaru is a business and maintenance is where they make their money. I have been trying to flush the brake system with new brake fluid and I would like to just change the other fluids as well anyway. Link to comment Share on other sites More sharing options...
MilesA Posted October 16, 2017 Share Posted October 16, 2017 Doing the fluid changes on time is important for longevity. Your car is newer than mine, but the schedule for mine calls for trans and diff oil changes every 30K. Brake fluid is simple to do when you change pads or at least every 2 to 3 years. I'm surprised the dealer wanted to do a coolant flush. The Super Blue coolant they have been using since 2009 or so is supposed to last 10 years. I wouldn't go that long, though. Maybe half that just to be on the safe side. Link to comment Share on other sites More sharing options...
Herda2448 Posted October 16, 2017 Author Share Posted October 16, 2017 I'm sure I can YouTube all this stuff since YouTube is a kind of library now. But are there tricks and tips that anybody has to make these flush processes easier? Always looking for advice. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
DrD123 Posted October 17, 2017 Share Posted October 17, 2017 For the 2012, recommended intervals are Brake fluid: replace every 30 months or 30k miles Coolant: replace after 11 yrs or 137,500 miles, then every 6 years or 75k miles Spark plugs: replace every 60 months or 60k miles Gear oil: inspect every 30 months or 30k miles (unless you tow a trailer, then replace every 15 months or 15k miles) Rear diff: inspect every 30 months or 30k miles (unless you tow a trailer, then replace every 15 months or 15k miles) Gear oil in the transmission and rear diff is a simple drain and fill Coolant is a simple drain and fill (a flush is not needed if you've been running OEM fluid) Brake fluid is a flush where you use the new fluid to flush the lines out to each caliper. At 98k miles, if none of that has been done, I'd do all of the above (plugs and fluids) - also, your engine air and cabin air filters, if they haven't been changed in 30k miles or more (15k for the in-cabin filter) How economical it is depends on how comfortable you are. Most of the drain and fill is pretty straightforward. For the brakes, if you've never bled a system before, have someone who has help you out (it's a two person job, unless you have a pressure bleeder, anyway). Plugs are annoying because space is limited (assuming the 2.5i is similar to the GT in that respect) Link to comment Share on other sites More sharing options...
DugsSin Posted October 17, 2017 Share Posted October 17, 2017 I'd do the power steering fluid also which is automatic trans. fluid Idemitsu ATF Type-HP. A small pump like thishttps://www.amazon.com/Plews-55001-Lubrimatic-Standard-Bottles/dp/B000BQW5LK is very helpful refilling things. It's all fairly simple after you've done it once. Link to comment Share on other sites More sharing options...
