lingling1337 Posted March 23, 2012 Share Posted March 23, 2012 The sound is a constant squeaking that is present regardless of speed or gear. I was thinking it's something to do with the brakes, maybe the clips, because when I apply the brakes the sound stops. The sound is pretty loud with the pass. window down but I can't hear it with the windows up. Nothing looks out of the ordinary on the brakes just from looking at it parked. Should I put it on stands and check it out or is there another probable cause for this problem? Link to comment Share on other sites More sharing options...
downtoearth Posted March 24, 2012 Share Posted March 24, 2012 does it get worse when your brakes are hot?! Link to comment Share on other sites More sharing options...
lingling1337 Posted March 24, 2012 Author Share Posted March 24, 2012 no, I dont think so, it seems pretty consistent. Link to comment Share on other sites More sharing options...
ShopTeacher Posted March 26, 2012 Share Posted March 26, 2012 Its probably the "tattle clips" little metal clips that are designed to inform the driver when the brakes are getting worn.....Check your brakes, you should see your answer. Link to comment Share on other sites More sharing options...
lingling1337 Posted March 26, 2012 Author Share Posted March 26, 2012 It definitely did not sound like the brake pad squeakers. I just re-greased everything and the sound went away. Bad news i actually did hear my squeakers, so I just bought some StopTech street pads for front and back. Link to comment Share on other sites More sharing options...
Max Capacity Posted March 26, 2012 Share Posted March 26, 2012 Could be a stone stuck between the rotor and backing plate. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
DosRenshos Posted March 27, 2012 Share Posted March 27, 2012 It could be that your front inside cv joint boot has split and let the grease out causing the joint to wear and start squeaking. This is a function of that boot being so close to the exhaust. Link to comment Share on other sites More sharing options...
lingling1337 Posted March 27, 2012 Author Share Posted March 27, 2012 It could be that your front inside cv joint boot has split and let the grease out causing the joint to wear and start squeaking. This is a function of that boot being so close to the exhaust. Guys I just used ceramic brake parts grease, the sound went away totally. Then my pads squeaked for a little bit but again they've stopped. Damn, guess I didn't need to drop that cash on new brake pads. Link to comment Share on other sites More sharing options...
RIPjeep2002 Posted May 7, 2012 Share Posted May 7, 2012 I have this same problem. Only after the car is warmed up. Nothing visually is wrong. Brakes don't feel like they are stuck. Right front passenger wheel. Below 20mph, rotational squeak. Heard best in a garage or next to other cars. Wheel intact, bearings have no play. What did you grease? Link to comment Share on other sites More sharing options...
lingling1337 Posted May 7, 2012 Author Share Posted May 7, 2012 I have this same problem. Only after the car is warmed up. Nothing visually is wrong. Brakes don't feel like they are stuck. Right front passenger wheel. Below 20mph, rotational squeak. Heard best in a garage or next to other cars. Wheel intact, bearings have no play. What did you grease? Just cleaned and greased every surface the pad touches- the abutment clips and the backs of the pads. Also double checked that the squealer tabs weren't bent or anything. I don't think whether the engine was warm had anything to do with my problem, but it's definitely a good idea to clean and grease everything. Link to comment Share on other sites More sharing options...
SpecBGuy Posted May 7, 2012 Share Posted May 7, 2012 hmmm i think i need to grease my brakes too. which grease did you use or any is fine. my first brake job:) Link to comment Share on other sites More sharing options...
lingling1337 Posted May 8, 2012 Author Share Posted May 8, 2012 hmmm i think i need to grease my brakes too. which grease did you use or any is fine. my first brake job:) Permatex ceramic brake grease, it's $15 for a tub online but I think I found it in small packets at my local auto parts tore. Link to comment Share on other sites More sharing options...
SpecBGuy Posted May 8, 2012 Share Posted May 8, 2012 most local stores sell the small one time use packets. thanks Link to comment Share on other sites More sharing options...
FJuan Posted May 8, 2012 Share Posted May 8, 2012 Don't forget to grease the Slide Pins, they are know to freeze after a few years. When they start sticking, the pads start to rub against the rotors while driving. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
lingling1337 Posted May 8, 2012 Author Share Posted May 8, 2012 Don't forget to grease the Slide Pins, they are know to freeze after a few years. When they start sticking, the pads start to rub against the rotors while driving. Good call, I forgot to mention those but I definitely greased those too Link to comment Share on other sites More sharing options...
