Moddiction Posted June 10, 2013 Share Posted June 10, 2013 The rear in my 08 legacy gt just started making these squeaking noises recently. Seems most common noises are from the sway bar bushings. Does this sound like that is the source of the noise? Or possibly shocks? Both sides bounce a bit after pushing down but this car has such soft suspension that might be normal. Car has 75k miles on it now. Stock suspension and all. http://i123.photobucket.com/albums/o281/ryangreene555/S2000%20pictures/682EF84A-011A-4B3F-94A7-8F04AF36CC46-46086-00001727336558FC_zps857dd61c.mp4 WWW.MODDICTION.COM Moddiction Stainless steel and Titanium shift knobs. Drivetrain, suspension, brakes, exhaust, cooling, fuel, gauges+MUCH more! Link to comment Share on other sites More sharing options...
Gmachine Posted June 11, 2013 Share Posted June 11, 2013 I just lubed my sway bushings,but they sounded nothing like that. Yours sound a bit more metallic . Car still ride the same? Look over your shocks for signs of oil leaks. Very easy to spot. Link to comment Share on other sites More sharing options...
Moddiction Posted June 11, 2013 Author Share Posted June 11, 2013 I've only had the car since January but it does drive the same since then. Recently had a downpipe put on but I don't see how that wold be related. Sound definitely seems to be coming from rear suspension. Only happens when I push down on the rear. Ill try to get it jacked up and take a look around. Just figured I'd post it up in case someone is familiar with that sound and what it might be. WWW.MODDICTION.COM Moddiction Stainless steel and Titanium shift knobs. Drivetrain, suspension, brakes, exhaust, cooling, fuel, gauges+MUCH more! Link to comment Share on other sites More sharing options...
08subieLGT Posted June 11, 2013 Share Posted June 11, 2013 Also check your endlinks. The bushings might be shot. Link to comment Share on other sites More sharing options...
DoctorLGT Posted May 7, 2014 Share Posted May 7, 2014 Hey. Bumping an old thread, but has anyone figured out what was wrong with this LGT? Moddiction, any luck figuring out/fixing this issue? Link to comment Share on other sites More sharing options...
Moddiction Posted May 7, 2014 Author Share Posted May 7, 2014 It's been intermittent and hasn't recently been happening. So I stopped caring. WWW.MODDICTION.COM Moddiction Stainless steel and Titanium shift knobs. Drivetrain, suspension, brakes, exhaust, cooling, fuel, gauges+MUCH more! Link to comment Share on other sites More sharing options...
