Moderators BarManBean Posted April 11, 2012 Moderators Share Posted April 11, 2012 Just realized I don't have the two bolts I'll need for this connection... Anyone know off the top of their heads what size should work here? I have the UP/turbo hardware and downpipe/turbo hardware...going to pickup DP/midpipe hardware from the dealer, just need the two bolts for UP/exhaust manifold. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
iNVAR Posted April 11, 2012 Share Posted April 11, 2012 whatever you use better be graded for exhaust use, or grade 8 bolts. don't use regular ole home depot stuff. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted April 11, 2012 Author Moderators Share Posted April 11, 2012 whatever you use better be graded for exhaust use, or grade 8 bolts. don't use regular ole home depot stuff. For sure. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
TRSCobra Posted April 11, 2012 Share Posted April 11, 2012 IIRC, most of the exhaust bolts/nuts are the same throughout the entire exhaust system. Link to comment Share on other sites More sharing options...
TRSCobra Posted April 11, 2012 Share Posted April 11, 2012 Double post! Link to comment Share on other sites More sharing options...
McKennaR Posted April 14, 2012 Share Posted April 14, 2012 P/n 44186 for the bolts and N370029 for the nuts. It's the same bolt / nut combo that is used on the top of the DP to turbo flange. They cost $8 at the local stealership if, say, you round one off because you're impatient and have to use an easy out on it like I did yesterday morning. Link to comment Share on other sites More sharing options...
