djnet5 Posted November 14, 2013 Share Posted November 14, 2013 So my 05 LGT has been really rough starting the past couple of mornings. I'm from PA, and it's just starting to dip below freezing around here lately. When I start my car, once I turn the key the motor begins to turn over, then cuts out, then will "sputter" as it begins to cuts out/cut in. Sometimes I have to try to start it all over again for it to work. When it is warm (50 degrees F+), there is no problem...it's only when it gets colder outside. It happened a few times last winter, but has since gotten worse and I had a point tonight where my car barely started. It begins to start, then seems to hit a point where it stops and just buzzes, then kicks back on again and begins to start again. I'm just seeing if anyone knows where to start with this. I don't know if it's the starter, the solenoid, or what...admittedly pretty inexperienced in these areas. I can even take a recording of the sounds. I just want to have an idea about it before I attempt to get it fixed. Thanks in advance! Link to comment Share on other sites More sharing options...
Gex Posted November 14, 2013 Share Posted November 14, 2013 Take a look at your starter. Grease the shaft the gear slides on. Its under the TMIC above the transmission. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 14, 2013 Share Posted November 14, 2013 Make sure the battery terminals are clean and tight, also the cable on the starter. How old is the battery ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
rob-2 Posted November 14, 2013 Share Posted November 14, 2013 Take a look at your starter. Grease the shaft the gear slides on. Its under the TMIC above the transmission. Anyone have a pic? I have the same over grin problem half the time. Link to comment Share on other sites More sharing options...
djnet5 Posted November 14, 2013 Author Share Posted November 14, 2013 Anyone have a pic? I have the same over grin problem half the time. Yes, a pic would be awesome. And the battery is less than one year old. Sent from my HTC6435LVW using Tapatalk Link to comment Share on other sites More sharing options...
BrownLeggy Posted November 14, 2013 Share Posted November 14, 2013 I have a similar problem, as well. Sometimes on really cold days, the starter stays extended and you can hear a slight grind for a second or two. I think I'm going to take my starter out and mess with it. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 14, 2013 Share Posted November 14, 2013 I have a similar problem, as well. Sometimes on really cold days, the starter stays extended and you can hear a slight grind for a second or two. I think I'm going to take my starter out and mess with it. This is a very common problem with these cars. remove the starter, put wheel bearing grease or a high temp grease on the shaft where the starter gear slides, reinstall starter. easy fix. The next common issue during cold weather is the smell of gas. It's caused by the clamps on the fuel line under #2 cylinder intake runner, I lock wired the hose on both sides of the clamp years ago and that stopped it. I think I posted pictures of it in my thread linked in my sig, "click here" below. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
stm25rs Posted November 15, 2013 Share Posted November 15, 2013 Some pics in this thread: http://legacygt.com/forums/showthread.php/swooshing-screech-sound-cold-start-up-starteri-ps-pumpi-audio-205081.html?t=205081 Also, the vacation pictures show the process to remove the starter. Link to comment Share on other sites More sharing options...
ehsnils Posted November 15, 2013 Share Posted November 15, 2013 Just make sure that the grease don't get too thick when it's cold and that's why it sticks. And clean before applying new grease. Link to comment Share on other sites More sharing options...
outahere Posted November 17, 2013 Share Posted November 17, 2013 So my 05 LGT has been really rough starting the past couple of mornings. I'm from PA, and it's just starting to dip below freezing around here lately. When I start my car, once I turn the key the motor begins to turn over, then cuts out, then will "sputter" as it begins to cuts out/cut in. ….. From the way you describe it, it sounds like the starter motor fully engages, but the engine will not fire??? Is that correct? Link to comment Share on other sites More sharing options...
