SUPERBU Posted September 7, 2007 Share Posted September 7, 2007 Ok guys after lots of demand I convinced Naz and Justin to build a box for the wagons. I was there last night until almost 11:00pm making this with Justin. This box looks awesome and contours to the body lines very nicely. It's nice and compact compared to other vendors 10" sub boxes. I took some quick pics of the progress. (Ignore the quality I left the D80 at home) Keep in mind this is the mock-up box and not the final product. PM Nazar or call 1-603-642-4222 http://img.photobucket.com/albums/v64/RC-NUT/SUBBOX3E.jpg http://img.photobucket.com/albums/v64/RC-NUT/SUBBOX2E.jpg http://img.photobucket.com/albums/v64/RC-NUT/SUBBOX1E.jpg Link to comment Share on other sites More sharing options...
RobE Posted September 7, 2007 Share Posted September 7, 2007 Looks good. http://newenglandsubarus.com/ Link to comment Share on other sites More sharing options...
str8dwn Posted September 7, 2007 Share Posted September 7, 2007 very interested. this would save me lots of time obviously. what is the approximate airspace and sub mounting depth? Link to comment Share on other sites More sharing options...
meier motor sports Posted September 7, 2007 Share Posted September 7, 2007 cool Link to comment Share on other sites More sharing options...
newbwrx Posted September 7, 2007 Share Posted September 7, 2007 Thanks for convincing Nazar to make one for the wagons! I am going to PM him right now. Link to comment Share on other sites More sharing options...
SUPERBU Posted September 7, 2007 Author Share Posted September 7, 2007 what is the approximate airspace and sub mounting depth? Once the box is finished I'll have that info for you. I would have to guess .75-.85 cu/ft of air space. We used a JL 10W6v2 for mock-up. Link to comment Share on other sites More sharing options...
praedet Posted September 7, 2007 Share Posted September 7, 2007 looks GREAT Link to comment Share on other sites More sharing options...
wukindada Posted September 7, 2007 Share Posted September 7, 2007 Very nice...... Did they ever do a finish cut on the top & Back edge?? Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
SUPERBU Posted September 7, 2007 Author Share Posted September 7, 2007 ^^^ I'm trying to figure out what you mean by finish cut? Link to comment Share on other sites More sharing options...
wukindada Posted September 7, 2007 Share Posted September 7, 2007 Not a flush seam on top edge or back..... Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
SUPERBU Posted September 7, 2007 Author Share Posted September 7, 2007 Oh ok. These photos are still in the early stage. There will be body filler added and the edges will be smooth. The box also looks better once it's bolted in because it pulls against the panels. The one difficult descission we had to make was how to contour the top to the seam where the black plastic and carpet meet. The plastic has a funky bend around to the door opening. At first we tried to keep the top of the box below that seem but once it meets up with the rear door it looks aweful. You can kind of see this in the first photo. (I probably lost you there.) Link to comment Share on other sites More sharing options...
subeysnow Posted September 7, 2007 Share Posted September 7, 2007 It looks good so far. In the 2nd pic, it looks as thugh the top is not flush and even with the other panels.... will the finish product? Just want to make sure it sits even, and I'm still able to use my trunk cover. Thanks. Link to comment Share on other sites More sharing options...
SUPERBU Posted September 7, 2007 Author Share Posted September 7, 2007 If you look closely that's actually a bag holder hook and not where your trunk cover locks into. I made sure the trunk cover has plenty of clearance. The box will not sit below the black plastic panel. If you follow the body line in the picture you will see why as you get closer to the rear door. It would have looked stupid and un-level. Link to comment Share on other sites More sharing options...
Canon20D Posted September 8, 2007 Share Posted September 8, 2007 Sweet!! Im first in line! This accepts a 10" or 12" woofer? Link to comment Share on other sites More sharing options...
SUPERBU Posted September 8, 2007 Author Share Posted September 8, 2007 This was designed for a flush 10" sub. A JL 10W3 or 10W6 would be perfect. I suppose a 12" would fit on the outer ring. The volume might not be enough depending on the driver. Link to comment Share on other sites More sharing options...
subeysnow Posted September 9, 2007 Share Posted September 9, 2007 how would this compare against the stealthbox? If it sounds good, put me down for one in black. Link to comment Share on other sites More sharing options...
16psibrick Posted September 9, 2007 Share Posted September 9, 2007 a subbox is a subbox, if it is well built, with the right space for the sub you choose, it will sound fine glad to see this finally get going...hehe Link to comment Share on other sites More sharing options...
Whirling Dervish Posted September 9, 2007 Share Posted September 9, 2007 Looks very nice! Good work! Link to comment Share on other sites More sharing options...
eb50 Posted September 10, 2007 Share Posted September 10, 2007 wow.. definitely want one but i have a stealthbox already... guess it all depends on the cost Link to comment Share on other sites More sharing options...
praedet Posted September 10, 2007 Share Posted September 10, 2007 This is made of fiberglass, the stealthbox is plastic. Overall, this will have more output, and cleaner output, than a stealthbox. (same driver and amp) That is because this will have less flex than the Stealthbox... Link to comment Share on other sites More sharing options...
subeysnow Posted September 10, 2007 Share Posted September 10, 2007 This is made of fiberglass, the stealthbox is plastic. Overall, this will have more output, and cleaner output, than a stealthbox. (same driver and amp) That is because this will have less flex than the Stealthbox... That's what I wanted to hear. Thanks. Link to comment Share on other sites More sharing options...
eb50 Posted September 10, 2007 Share Posted September 10, 2007 That's what I wanted to hear. Thanks. i want to hear the price range around 200$ Link to comment Share on other sites More sharing options...
msmith Posted September 11, 2007 Share Posted September 11, 2007 This is made of fiberglass, the stealthbox is plastic. Overall, this will have more output, and cleaner output, than a stealthbox. (same driver and amp) That is because this will have less flex than the Stealthbox... Whoa, easy there partner... all Stealthbox systems (except for the BMW 3-series pods) are made of 100% fiberglass (no fleece, cloth or other material). You have us confused with MTX or something. Learn more: http://mobile.jlaudio.com/products_stealthbox_pages.php?page_id=169 Link to comment Share on other sites More sharing options...
16psibrick Posted September 11, 2007 Share Posted September 11, 2007 This is made of fiberglass, the stealthbox is plastic. Overall, this will have more output, and cleaner output, than a stealthbox. (same driver and amp) That is because this will have less flex than the Stealthbox... as far as i know nad have seen, stealthboxes are fiberglass, maybe selected models? i know Q logic boxes are uh...another matter, and thunderform truckboxes i know are somehwat plsaticy...but i havent a plastic stealthbox yet, all the stealthboxs i have seen are fiberglass, even the LGT ones. could it be thicker in some instances? perhaps...but honetsly, i dont think they really sound much different than most of hte subboxes i have done with somewhat similar designs... oh oops, manville already posted lol Link to comment Share on other sites More sharing options...
praedet Posted September 11, 2007 Share Posted September 11, 2007 Sorry about that, I was passing on what I heard from a guy who competes in car audio, no harm meant Manville Link to comment Share on other sites More sharing options...
