bluesuby Posted March 7, 2011 Share Posted March 7, 2011 I have a 2005 LGT Wagon with Koni Shocks, Whiteline LCA bushings, and otherwise a stock suspension. When the Konis were installed I left them on the full soft setting, thinking they would produce a very firm ride. Actually they did feel really good, but I'm playing with the idea of turning them one "click" in the front only. I rarely keep anything in the back of the wagon, and 90% of the time I drive to/from work by myself. Anyone have any thoughts on what the consequences would be of firming up the front a bit more, but leaving the rear in full soft? Link to comment Share on other sites More sharing options...
MDW25gt Posted March 8, 2011 Share Posted March 8, 2011 Try it and see. Link to comment Share on other sites More sharing options...
N.sane Posted March 8, 2011 Share Posted March 8, 2011 Since the rear spring rate is higher than the front, shouldnt the rear be set a bit firmer? Stock spring rates are 3.5 front, 5.5 rear. Link to comment Share on other sites More sharing options...
bluesuby Posted March 8, 2011 Author Share Posted March 8, 2011 Since the rear spring rate is higher than the front, shouldnt the rear be set a bit firmer? Stock spring rates are 3.5 front, 5.5 rear. I don't know. I was hoping some autocross people might know whether turning down the fronts would move toward oversteer, increase understeer, or move toward neutral. Link to comment Share on other sites More sharing options...
bnguyenbb6 Posted March 8, 2011 Share Posted March 8, 2011 Set them however you like them. Turning down just the fronts does create a bit more turn in. I usually set them full hard then dial back depending on how I feel. Usually like half a turn back in the fronts. Its all about how you feel... Link to comment Share on other sites More sharing options...
N.sane Posted March 8, 2011 Share Posted March 8, 2011 From what I've learned, the advantage of having the adjustability of the Koni's is to match the dampening with the springs you have, not to correct oversteer and understeer. If you're looking to adjust oversteer and understeer, you can adjust your alignment settings, tire pressure, and sway bar(s). Link to comment Share on other sites More sharing options...
whitetiger Posted March 8, 2011 Share Posted March 8, 2011 As a rule of thumb, shocks are at their best when they are in the middle of their adjustment range as opposed to setting them at the limits(high or low) of their adjustment range. id keep them a couple clicks off the limit. Link to comment Share on other sites More sharing options...
bluesuby Posted March 8, 2011 Author Share Posted March 8, 2011 As a rule of thumb, shocks are at their best when they are in the middle of their adjustment range as opposed to setting them at the limits(high or low) of their adjustment range. id keep them a couple clicks off the limit. And use the same adjustments front and rear? Link to comment Share on other sites More sharing options...
KartRacerBoy Posted March 8, 2011 Share Posted March 8, 2011 Since the rear spring rate is higher than the front, shouldnt the rear be set a bit firmer? Stock spring rates are 3.5 front, 5.5 rear. Depends on the suspension geometry. If front suspension has lower rates in front (despite being the heaviest part of the car), methinks it is becz the front springs are subject to leverage, so despite the lower spring rate, the real spring rate as teh suspension moves through its range of motion is probably higher than the rear spring rate. Link to comment Share on other sites More sharing options...
brum Posted March 8, 2011 Share Posted March 8, 2011 I run 1 turn in front and 1.5 in rear. It's pretty sweet. Link to comment Share on other sites More sharing options...
G35C_WRX_MX5_MR2 Posted March 9, 2011 Share Posted March 9, 2011 I run 1 turn in front and 1.5 in rear. It's pretty sweet. This is how I run mine in my wagon too. I think you'll find these settings actually slightly softer than what you are currrently running. Adjustable shocks shouldn't be run at their lowest setting. Link to comment Share on other sites More sharing options...
whitetiger Posted March 9, 2011 Share Posted March 9, 2011 And use the same adjustments front and rear? no, they can be whatever you want, just as long as you are off the upper or lower limits of the adjustment. Link to comment Share on other sites More sharing options...
KCwagon Posted March 9, 2011 Share Posted March 9, 2011 I think it is weird that you didn't spend the first week adjusting them several times a day. I did find with my particular set-up that a full turn from soft in the front actually improved the ride. I have the rears adjusted about a turn and a quarter. Link to comment Share on other sites More sharing options...
AZP Installs Posted March 13, 2011 Share Posted March 13, 2011 When I had them on my LGT I ran them 1.5 turns from soft in front and 1.0 turns from soft in rear. -mike http://www.pbase.com/paisan/image/91072632.jpg AIM: AZP Installs | E-mail: paisan@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 "Race Tested, Enthusiast Approved!" Link to comment Share on other sites More sharing options...
naimouasta Posted March 14, 2011 Share Posted March 14, 2011 yep thats how i have mine. i think its better with it higher up front. i figure more weight in the front so it needs to be dampened more vs the rear. Link to comment Share on other sites More sharing options...
