spiky Posted February 17, 2018 Share Posted February 17, 2018 Hi all, I got the code P3001 on scanner which is oxygen sensor upstream. I'm going to replace it myself but after i do that do i need to clear ECU or it does gone off by itself after replacement. Or if not how to clear ECU on the dashboard. thank you for all advice. Link to comment Share on other sites More sharing options...
spiky Posted February 17, 2018 Author Share Posted February 17, 2018 ... Link to comment Share on other sites More sharing options...
janfar Posted February 17, 2018 Share Posted February 17, 2018 You will need to clear it. 2 ways to do it. Use the same scanner or... Some people say you can disconnect the battery for an hour-long. I have never tried this as I have a scanner. Sent from my ONEPLUS A3000 using Tapatalk Link to comment Share on other sites More sharing options...
relative4 Posted February 17, 2018 Share Posted February 17, 2018 What kind of car do you have? Are you sure about that code? Not P0301? Where did you look up that definition for the code? Link to comment Share on other sites More sharing options...
spiky Posted February 17, 2018 Author Share Posted February 17, 2018 relative4 I have 05 legacy gt, I'm not sure about code number but the shop said it was oxygen sensor bank 1. janfar I don't have scanner with me but that the only way to clear ECU to disconnect the negative battery? Link to comment Share on other sites More sharing options...
relative4 Posted February 17, 2018 Share Posted February 17, 2018 AT or MT? The first thing you need to do is pull the correct code. An auto parts store can do that for free. Link to comment Share on other sites More sharing options...
apexi Posted February 17, 2018 Share Posted February 17, 2018 sounds like P0031 "P0031 HO2S Heater Control Circuit Low (Bank 1 Sensor 1)" Link to comment Share on other sites More sharing options...
ehsnils Posted February 17, 2018 Share Posted February 17, 2018 Buy a code reader and read the code first. That would tell you what's up. Then you can reset it and see if it comes back. Not having a code reader when you have an old car is like not having a set of tools and a spare alternator belt with you in case you need to make a quick roadside fix. Link to comment Share on other sites More sharing options...
59ctd Posted February 17, 2018 Share Posted February 17, 2018 I'd recommend one of the bluetooth OBDII scanners that links to your Android phone or tablet. Or they have WiFi versions too for IOS. Each are less than $20 and they allow you to reset/erase the codes as well. I use the Torque app on mine. Link to comment Share on other sites More sharing options...
janfar Posted February 17, 2018 Share Posted February 17, 2018 What they said. Mine is partially useless because previous owner ecutekd it but for reading and clearing it works a charm. Link to comment Share on other sites More sharing options...
spiky Posted February 18, 2018 Author Share Posted February 18, 2018 thank you you all info, I got the code now is P0031 heated oxygen sensor-bank1 sensor1. The check engine light was on and cruise control were flashing. My question is after i have replace the oxygen sensor how do i reset ECU I searching on the site said just disconnect the negative battery for an hour do they have another way to reset it or that is the only way to do. thank again. Link to comment Share on other sites More sharing options...
relative4 Posted February 18, 2018 Share Posted February 18, 2018 If you replace the O2 sensor, and the sensor is in fact the problem, the CEL will go away on its own. If somehow it doesn't, the auto parts store can clear it for you, or you can clear it with a $10 basic reader from eBay. If the CEL returns, the solution applied was not the correct one. If you want to diagnose properly before replacing the part, refer to the P0031 procedure in the vacation pics. Link to comment Share on other sites More sharing options...
ttnio Posted February 19, 2018 Share Posted February 19, 2018 10-4 on that (cel) going away on its own if replaced correctly. Mine went away in less than 5 miles as soon as I drove to test... Link to comment Share on other sites More sharing options...
janfar Posted February 20, 2018 Share Posted February 20, 2018 The 'light' will go away but the code will be stored. So if you ever have a CEL again and you go for a scan it will still pull up the old code together with any other new codes. This will throw off your investigation. Link to comment Share on other sites More sharing options...
