spec.B Dream Posted April 18, 2014 Share Posted April 18, 2014 Yea. That's been discussed in this thread. Just bug with a slightly annoying temporary effect. It usually happens on the cooler mornings of warmer days with the heat on. Makes me think it might be humidity related because it doesn't happen on cold dry winter days with the heat on. Sent from my Nexus 4 using Tapatalk Link to comment Share on other sites More sharing options...
Schrei Wolf Posted April 18, 2014 Share Posted April 18, 2014 Boost, Oil Pressure and Wideband O2 sounds nice. Time to start putting away some coin. Link to comment Share on other sites More sharing options...
gordata Posted April 19, 2014 Share Posted April 19, 2014 Installed mine this morning, bought from another member here, this unit is slick. http://i962.photobucket.com/albums/ae106/SergioMorel/Legacy/2014-04-19091634_zpsf941eb75.jpg Link to comment Share on other sites More sharing options...
evildriver Posted May 5, 2014 Share Posted May 5, 2014 As much as I'd love to read through 91 pages of posts... Wait no I wouldn't. Who has gotten boost and afr on these things? I have a couple questions Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted May 5, 2014 Moderators Share Posted May 5, 2014 As much as I'd love to read through 91 pages of posts... Wait no I wouldn't. Who has gotten boost and afr on these things? I have a couple questions I'm running both, with a PLX wideband setup. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
evildriver Posted May 5, 2014 Share Posted May 5, 2014 you will have a pm shortly, sir. Link to comment Share on other sites More sharing options...
discojon Posted May 5, 2014 Share Posted May 5, 2014 I'm running both, with a PLX wideband setup. I am also running boost and plx v3 Afr. Let me know if bmb doesn't fix you up Link to comment Share on other sites More sharing options...
evildriver Posted May 5, 2014 Share Posted May 5, 2014 thanks, BMB straightened things out. curious, did you buy the datalogging cable from PLX or DIY? Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted May 5, 2014 Moderators Share Posted May 5, 2014 thanks, BMB straightened things out. curious, did you buy the datalogging cable from PLX or DIY? Did you get my last message with DIY info? (credit goes to Strizzy for all of that info, but it's good stuff!) "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
evildriver Posted May 5, 2014 Share Posted May 5, 2014 yep, I did. thanks. i'm just curious what others have done as I don't necessarily have the time or resources to DIY it. Link to comment Share on other sites More sharing options...
discojon Posted May 5, 2014 Share Posted May 5, 2014 thanks, BMB straightened things out. curious, did you buy the datalogging cable from PLX or DIY? I got it from PLX. however, a simple Google search of the part number lists it at several other locations, mostly over seas, for considerably less... a side note: When I have both the VBG and laptop plugged in (via a y splitter) and the laptop battery dies, the VBG won't connect to the PLX SM AFR until I unplug the data logging cable from the splitter. Link to comment Share on other sites More sharing options...
Strizzy Posted May 5, 2014 Share Posted May 5, 2014 My last DIY cable went out, mainly due to a parent not understanding how auxiliary music cables work. As I mentioned to BMB in a past PM, I purchased one of these, http://www.ebay.com/itm/310742466145, and recently soldered a 3.5mm headphone jack on the end, then downloaded and installed the drivers to my laptop. The cable works perfectly, with zero need for supplies other than the 3.5mm headphone jack. If you don't mind waiting for a month, you can get it cheaper from China/Hong Kong. I prefer to buy from US sellers to get it sooner. As long as you hook up the VCC and Rx to the right terminals, nothing can really go wrong. My bad luck build Link to comment Share on other sites More sharing options...
Scooby2.5 Posted May 6, 2014 Share Posted May 6, 2014 I have mine with a LC-1 works great Link to comment Share on other sites More sharing options...
evildriver Posted May 26, 2014 Share Posted May 26, 2014 having some install troubles... plugged the flex cable into the gauge (black side up) and secured it. connected add-a-fuse to power wire. connected grounding wire to screw on circuit box. plugged power into sending unit. the gauge does nothing when i turn the car on. i tried a larger fuse just for shits and giggles and still nothing. tried re-crimping all connectors, nothing. double checked flex cable, nothing. any thoughts? Link to comment Share on other sites More sharing options...
spec.B Dream Posted May 26, 2014 Share Posted May 26, 2014 Do you have both fuses in the add a fuse? Sent from my Nexus 4 using Tapatalk Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted May 26, 2014 Moderators Share Posted May 26, 2014 Remove the add a fuse and just wrap the power wire around one leg of the normal fuse and reinsert it. See if that helps. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
ERLoft Posted May 26, 2014 Share Posted May 26, 2014 Any idea when these will be available again? 2013 █S4 - Glacier White - DSG - B&O - Tech Package - Sports Diff - Napa - RS4 Grille - Stasis Exhaust - APR Intake - KW Variant 1 - Stern Control Arms - CR-15 - Stasis RSB - Moog Endlinks - PC Hyper Black Peelers - Deval Front Lip - ECS Rear Diffuser - Carbon Imports Ducktail - ECS Mirror Caps - Relak Paddle Extensions - Autostyle Floor Mats - LED Interior - V1 - Blackvue DR900s - [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
evildriver Posted May 26, 2014 Share Posted May 26, 2014 Do you have both fuses in the add a fuse? Sent from my Nexus 4 using Tapatalk both fuses did the trick. knew it was something simple i was missing. should it be 7.5 amp fuses in both? Link to comment Share on other sites More sharing options...
evildriver Posted May 29, 2014 Share Posted May 29, 2014 FYI, looks like there is one in stock on the website right now... Link to comment Share on other sites More sharing options...
BoozeRS05 Posted May 30, 2014 Share Posted May 30, 2014 I was digging around in the fuse panel area the other day and found the previous owner had installed a add-a-fuse for a V1 radar. Gonna use it for the dimming function on my VBG EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
Shaid Posted June 20, 2014 Share Posted June 20, 2014 Any idea when these will be available again? Soon i hope Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted July 10, 2014 Moderators Share Posted July 10, 2014 I don't recall, can we use these to run boost as well as AFR *and* oil pressure yet? Or still stuck picking between AFR and oil pressure? "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
ShadowImg Posted July 14, 2014 Share Posted July 14, 2014 lossol hasn't indicated the dual input firmware to exist yet, as far as I know. Link to comment Share on other sites More sharing options...
BoozeRS05 Posted July 15, 2014 Share Posted July 15, 2014 Is anyone getting some aesthetic markings on theirs? Mines kind of spotting in areas on the display face. EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
ShadowImg Posted July 15, 2014 Share Posted July 15, 2014 Does it look like it's kind of de-laminating from itself? If so, yes. There's some discussion of it earlier on in this thread. I was actually supposed to get a photo of it for him, but I could never actually capture it in a photo and forgot about it. Link to comment Share on other sites More sharing options...
