Razor Posted January 20, 2012 Share Posted January 20, 2012 Hey guys, I'm having a strange problem. My "emergency brake" light has been staying on the last few weeks. At first It only came on during WOT and would clear after a few days. now its constant. I'm throwing no codes that I can see on my cobb reader. Any ideas? this might be a simple one... Link to comment Share on other sites More sharing options...
Max Capacity Posted January 20, 2012 Share Posted January 20, 2012 Check the brake fluid level. Then check the switch under the E brake handle. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
AZP Installs Posted January 23, 2012 Share Posted January 23, 2012 This means your brake pads need replacement. Essentially, when the pads run low, the fluid goes low and the brake light comes on to let you know. DO NOT JUST TOP OFF YOUR FLUID. -mike http://www.pbase.com/paisan/image/91072632.jpghttp://www.pbase.com/paisan/image/141039922.jpg http://www.pbase.com/paisan/image/133406601.jpg http://upload.pbase.com/image/137566671.jpg Call directly as We carry almost every manufacturer now, so before you buy parts call us. AIM: AZP Installs | E-mail: [emjail]paisan@azpinstalls.com[/email] | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber "Race Tested, Enthusiast Approved!" Link to comment Share on other sites More sharing options...
