chaz517 Posted October 7, 2014 Share Posted October 7, 2014 Hey guys, installed my Innovative LC2 Wideband, and it reads 10.7 at idle, jumps around a bit, and 10.8 and 10.9 at wot. Is that accurate? At partial throttle on light loads, it drops to 7.8 and around there. That can't be right since that is soooo rich Link to comment Share on other sites More sharing options...
CapnJack Posted October 8, 2014 Share Posted October 8, 2014 Something isn't correct. Have you performed a free air calibration on it yet? Link to comment Share on other sites More sharing options...
chaz517 Posted October 8, 2014 Author Share Posted October 8, 2014 Yes sir I have. I will have to check the ground tomorrow morning. Weird,and annoying. Link to comment Share on other sites More sharing options...
chaz517 Posted October 9, 2014 Author Share Posted October 9, 2014 No luck with anything. Anyone else? Link to comment Share on other sites More sharing options...
compsurge Posted October 9, 2014 Share Posted October 9, 2014 Check the wiring. Most sensors like this operate on a 0-5V scale. If the ground reference is bad, it will not be able to read correctly. Where did you connect ground? Where did you source the 12V signal? Link to comment Share on other sites More sharing options...
