WesleySands Posted March 2, 2015 Share Posted March 2, 2015 Since we seem to be having a heatwave, he he (temps above 20 deg.) I was thinking of doing some proactive maintenance to the car. I had a question about the fuel injectors, I was thinking about cleaning them. With my Olds 3.6 litre, I pulled them out and dumped them in Simple Green and they were great after that. I'd even had an old mechanic suggest that one to me. My question is can I do the same thing to Scooby injectors? Everything. I've read says its not worth cleaning them but for $70 each, I'd rather do some work on the ones I have. I also don't have the time to be w/o a car by sending them off to WitchHunter. Or should I run a can of seafoam through it at the next fill up? Thank you Link to comment Share on other sites More sharing options...
93ej22 Posted March 2, 2015 Share Posted March 2, 2015 I am a fan of seafoam when I buy a used car the first thing I do is go pick up a couple cans and runs some in the gas and some in the oil before I change all the fluids however I don't see any problem with the simple green approach, I have actually heard of a few people making a basic little hot tank with simple green and a crock pot or similar to clean their parts Link to comment Share on other sites More sharing options...
bluesuby Posted March 2, 2015 Share Posted March 2, 2015 I'm a Techron fan. Fill up and dump a 20 oz bottle in. If you have Chevron gasoline in your area, there's Techron added at the refinery. Link to comment Share on other sites More sharing options...
Tr00b Posted March 3, 2015 Share Posted March 3, 2015 Marvels Mystery Oil is what I use. Link to comment Share on other sites More sharing options...
monkeyposeur Posted March 3, 2015 Share Posted March 3, 2015 Check for a local fuel injector shop if you don't want to send them to witch hunter. Link to comment Share on other sites More sharing options...
SoSubiZ Posted March 3, 2015 Share Posted March 3, 2015 When I was an infiniti tech, "at least at my dealer" we used these kinda deals. And they work well. http://www.autobodytoolmart.com/otc-fuel-injector-cleaning-kit-7649-p-14727.aspx?kpid=18292&gclid=CPOKyMCmi8QCFY-Vfgodi68AGQ Since there is no fuel port on our cars. You may have to improvise if you wanna go this route. I know there's a small rubber hose going to the fuel pressure regulator you may be able to rig one of these too. I've never had to check fuel pressure or clean my injectors on my subi. Fuel additives are good stuff, Best advice always use top tier gas. We have drained full tanks of cheap gas, replaced with high quality and seen night and day differences in how cars run. And why do you think they need cleaning? misfires? If your CEL is off and it doesn't misfire I personally wouldn't worry about it. Link to comment Share on other sites More sharing options...
WesleySands Posted March 3, 2015 Author Share Posted March 3, 2015 The CEL is on, but a previous wanker ripped the wire to the 16 pin so my obdII port is useless. It runs fine, but every so often if I'm holding speed and rpm steady I can feel it surge. It's not that big a deal. So mainly its preventative, and at 201,xxx miles, w/ the state of some of the 'repaire' I've seen, I don't put much stock in how things were previously done. Thank you for all the replies. Link to comment Share on other sites More sharing options...
SoSubiZ Posted March 3, 2015 Share Posted March 3, 2015 Fixing the connector I would do first. A surge could be a random bad spark as well. check plugs. Link to comment Share on other sites More sharing options...
WesleySands Posted March 3, 2015 Author Share Posted March 3, 2015 I've been wanting to fix the wire but there's no obvious breaks, so unless he pulled it from the source, which I'm unsure where power derives from. Also the fuse is good but the cigar lighter doesn't work. I know they're on the same fuse so I think its after the fuse box. The plugs and wires are new, I'd already checked the coil pack as well. One more question, if I pull the injectors, will I screw up the 'balance' of them? Link to comment Share on other sites More sharing options...
SoSubiZ Posted March 4, 2015 Share Posted March 4, 2015 unless of some freak situation because they have been seated in there so long. no Link to comment Share on other sites More sharing options...
WesleySands Posted March 4, 2015 Author Share Posted March 4, 2015 Excellent, thank you all, you've been most informative Link to comment Share on other sites More sharing options...
