bcmaxx Posted May 4, 2013 Share Posted May 4, 2013 our 92 legacy started pinging terribly!!! under load the worst, sounds like a piston about to shoot out, under light accell its fine, and when its cold, same its perfect. knock sensor? theres no cel light or anything, has had new plugs, fuel wires, coil maf, and coolant temp sensors all within the last 10,000kms Link to comment Share on other sites More sharing options...
Tangointhenight Posted May 4, 2013 Share Posted May 4, 2013 What spark plugs do you have? If they're Bosch or domestic, replace them with NGK or Denso. You can also try fuel system cleaner or Seafoam. Also, have you tried higher octane, and if you have, what happens then? Head gasket problems can also cause pinging Link to comment Share on other sites More sharing options...
snederhiser Posted May 5, 2013 Share Posted May 5, 2013 Hello; Knock sensor would be the likely suspect. Also check timing, and the cam/crankshaft sensors. Also check the ecu for stored codes. You may not have a hard fault yet to set off the light but enough for a stored code! Steven. Link to comment Share on other sites More sharing options...
bcmaxx Posted May 30, 2013 Author Share Posted May 30, 2013 ngk plugs, number 22401aa310, knock sensor 22060aa031, new ngk wires, new coil 22433aa370, still pinging pretty good under load. no mechanical engine noise whatsoever. very frustrating!! seems to lack power too, fuel consumption also seems high, could a crappy 02 sensor cause this? It has a bwd direct plug in sensor.no codes either Link to comment Share on other sites More sharing options...
bcmaxx Posted May 30, 2013 Author Share Posted May 30, 2013 i have seafoamed it, ran it in tank, and tried octane boost with 91 octane, still pings. no sign of headgasket issue, no trace of exhaust oil in coolant, no external leaks. Link to comment Share on other sites More sharing options...
mnstrmech Posted May 31, 2013 Share Posted May 31, 2013 weak fuel pump. try checking fuel pressure. Link to comment Share on other sites More sharing options...
bcmaxx Posted May 31, 2013 Author Share Posted May 31, 2013 alright, will do, dont know why I forget the basics sometimes... I noticed the fuel pump isnt under the seat? drop tank to replace? Link to comment Share on other sites More sharing options...
snederhiser Posted June 1, 2013 Share Posted June 1, 2013 Hello; Pull up the trunk mat and look for a oval cover behind the seat on the right hand side. You can pull the return line and see if there is fuel returning to the tank if you don't have a pressure gauge. I am talking about the one under the hood. Check your cam sensor and knock sensor. Do yourself a favour and go to the only sticky we have for the first generation. Click on notes & tips, then tech articles, look for the FSM (92 manual). Download this, Steven. Link to comment Share on other sites More sharing options...
bcmaxx Posted June 5, 2013 Author Share Posted June 5, 2013 pump good, pressure and flow good, trying oem front oxygen sensor tonight, and hopefully some injectors in the next couple days. Also thinking my bigger tires arent helping matters especially in fuel dept, maybe drop back to a 16" 205/55/16 Link to comment Share on other sites More sharing options...
monkeyposeur Posted June 6, 2013 Share Posted June 6, 2013 Fuel pump replacement DIY: http://legacygt.com/forums/showthread.php/walbro-255-lph-install-diy-198427.html Link to comment Share on other sites More sharing options...
snederhiser Posted June 8, 2013 Share Posted June 8, 2013 Hello; Pull the front covers and check the timing, could have skipped a tooth somewhere. Steven. Link to comment Share on other sites More sharing options...
bcmaxx Posted June 11, 2013 Author Share Posted June 11, 2013 next on my list, it had a new oil pump very recently Link to comment Share on other sites More sharing options...
05LGTLtd Posted June 13, 2013 Share Posted June 13, 2013 Exhaust flow good? All I need now is a hill holder and a center passing light... Link to comment Share on other sites More sharing options...
jp233 Posted June 13, 2013 Share Posted June 13, 2013 check for stored codes, for sure. You can test the injectors at least to hear them click, but that will not tell you about real flow. I've had WitchHunter clean/flow test several sets of injectors and you'd be amazed how well a car will run with crappy injectors, though. Crank and cam sensors, definitely check. Timing, yep that too. Count your teeth and make sure those cams are lined up right! Link to comment Share on other sites More sharing options...
bcmaxx Posted August 20, 2013 Author Share Posted August 20, 2013 fuel pump........ guess it was intermittent, tried to pull a summit and it kept running out of fuel. replaced all good, power back, hopefully fuel mileage too! Link to comment Share on other sites More sharing options...
mnstrmech Posted August 26, 2013 Share Posted August 26, 2013 i was right then?...... im always right. lol. Link to comment Share on other sites More sharing options...
bcmaxx Posted August 26, 2013 Author Share Posted August 26, 2013 almost, still pinging, sounds like just the drivers bank....I may replace lifters on the one side, maybe collapsed Link to comment Share on other sites More sharing options...
USLiberty Posted August 27, 2013 Share Posted August 27, 2013 Collapsed lifters are noisy at idle, is yours? No sense replacing everything. How are your grounding points? Theres one on each side, next to the camgears attached to the frame rails that get corroded easily. Easy/cheap to clean with wire brush or flat screwdriver. Then I would do a pressure check on your radiator/cooling system, autozone here has a gauge for rental, it goes in place of your radiator cap and you pressurize it and see if it holds. most mechanics have one. I sound like a broken record but its a quick/easy way to check if heads are cracked. After that was confirmed good, I'd run a compression test. If timing is right, compression is good in all cylinders then id check into the electronics. Link to comment Share on other sites More sharing options...
