tfa1337 Posted May 27, 2013 Share Posted May 27, 2013 Hello all, Have been in need of an affordable, reliable car for awhile as my current is about toast. Found a local listing on craigslist for a 99 Legacy SUS. Says its had quite a bit of work done recently. Seems to have had all common problems with these models taken care of, except maybe a timing belt... Curious if this is worth the asking price, or if I should keep on looking. Pictures show good external condition.1999 Subaru AWD SUS Four Door Sedan Approximately 125,000 miles New parts within the past year: Rear rotors/drum, calipers, brakes(drum and disc), brake shoe hardware, and brake lines Front rotors, wheel bearings, wheel hubs, splash guard plates, ball joints, toner wheel Head gasket set, heads redone, serpentine belt, upper and lower radiator hoses and clamps, spark plugs Starter, water pump, thermostat, Oil filter and oil change, 4 wheel alignment at Subaru dealer (Have receipts for all of the above) (has had hail damage) Needs a remote. $4900 OBO Thanks! Link to comment Share on other sites More sharing options...
