Vtsubiers Posted December 29, 2012 Share Posted December 29, 2012 Previous owner hit something with the passenger side mirror: http://i5.photobucket.com/albums/y171/xcellr8edaudi3/PC230086.jpg everything is still functional, but I get condensation inside. is it possible to buy just the clear section and replace, or do I need to replace the whole cover? thanks in advance. Link to comment Share on other sites More sharing options...
JJr Posted December 29, 2012 Share Posted December 29, 2012 Mine was the same (05 LGT). Bought a used mirror (here apprx. $70) be patient they will show up. Impreza? Replaced the used skull with mine, had to pull the door panel to remove mirror assembly. Otherwise check the dealer, you may get sticker shock, I did. GL Link to comment Share on other sites More sharing options...
CapnJack Posted December 30, 2012 Share Posted December 30, 2012 Can be purchased separately. I'm assuming its for a 2005? http://parts.subarupartswarehouse.com/parts/2005/SUBARU/LEGACY/?siteid=214327&vehicleid=1430733&diagram=7523600&diagramCallOut=5 This site has 25% off all prices until 12-31-12 with coupon code YE12. Link to comment Share on other sites More sharing options...
Vtsubiers Posted December 30, 2012 Author Share Posted December 30, 2012 sorry its for 08 legacy 3.0r, passenger side is right? drivers is left? http://parts.subarupartswarehouse.com/parts/2008/SUBARU/LEGACY/3.0%20R%20LIMITED/?siteid=214327&vehicleid=1440459§ion=BODY%20HARDWARE&group=FRONT%20DOOR&subgroup=OUTSIDE%20MIRRORS Link to comment Share on other sites More sharing options...
Vtsubiers Posted March 5, 2013 Author Share Posted March 5, 2013 bump.. part number for clear indicator section of mirror- passenger side. thanks Link to comment Share on other sites More sharing options...
Vtsubiers Posted March 6, 2013 Author Share Posted March 6, 2013 alright, on subarugenuineparts... #6 has no part number with it.... i will keep browsing. rh is passenger yes? Link to comment Share on other sites More sharing options...
pilotxp Posted March 6, 2013 Share Posted March 6, 2013 I had same problem only FILLING with water in rain storms. Drilled small hole, blew out water with air nozzle, filled hole with clear silicone. You really can't see it at all and so far so good. Oh, also ran very tiny clear silicone bead down between mirror body and clear blinker lens. Not elegant but it works until I can find a reasonable $$ replacement! Link to comment Share on other sites More sharing options...
