Lafta Posted March 24, 2014 Share Posted March 24, 2014 Hey guys, I'm thinking about getting my engine and undercarriage/engine steam cleaned. Is there any risk with this, that might ef up the engine/electrical, etc. ? If there *is* risk to the engine, is there risk to cleaning the undercarriage and bottom of the engine?? Link to comment Share on other sites More sharing options...
lockmedic Posted March 24, 2014 Share Posted March 24, 2014 I do it all the time. I try to not blast stuff like the alternator or any connectors directly with the pressure washer, but that's about it. I ruined a bearing in an alt once, but I think it was on the way out anyway (grease seal was compromised). I use a hot water pressure washer that's capable of steam but I rarely crank it up that high. 4000 psi at 240F (turns to a mix of steam/very hot water when it exits the nozzle) will eff stuff up if you're not careful. Link to comment Share on other sites More sharing options...
Lafta Posted March 24, 2014 Author Share Posted March 24, 2014 Link to a local company that does engine and undercarriage steam cleaning. Scroll down..... http://splashes.ca/services/detailing.html Any more replies would be greatly appreciated. Link to comment Share on other sites More sharing options...
theflystyle Posted March 24, 2014 Share Posted March 24, 2014 You could cover the delicate electric bits with plastic to help make sure they are not damaged. Link to comment Share on other sites More sharing options...
Perscitus Posted March 25, 2014 Share Posted March 25, 2014 I use a steam washing detail shop in Rye, NY (Birdie's Auto Spa) and have yet to have any problems. Outside = steamed Inside = steamed Engine bay = steamed Done both summer and winter and 0 issues. Like the other guys mentioned above, if done professionally, with some built-in safety, distance between the nozzle and the paint/surfaces, etc. this is a very safe way to clean your car. Better than any chemicals out there. Link to comment Share on other sites More sharing options...
Max Capacity Posted March 26, 2014 Share Posted March 26, 2014 I used to clean the engine at the car wash, leave it running and stay away from things you know better then to get really wet. Use your head. Or just drive the car on rainy day in April to get it rinsed off under the chassis to get all the winter salt crap off from going to skiing at that little place by you. Yea, I'm jealous...LOL 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
700watts Posted March 26, 2014 Share Posted March 26, 2014 Just don't get soap on the inner-cooler Link to comment Share on other sites More sharing options...
Max Capacity Posted March 27, 2014 Share Posted March 27, 2014 Just don't get soap on the inner-cooler Make that, inter-cooler. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
700watts Posted March 27, 2014 Share Posted March 27, 2014 spell-checks a b!5ch Link to comment Share on other sites More sharing options...
OCDetails Posted March 31, 2014 Share Posted March 31, 2014 If there was risk then your engine would be sealed in a waterproof container. Unless your engine is made of sugar then you really don't have much to worry about when it comes to steam cleaning. High pressure washing is another story, but steam isn't going to hurt it. _________________________________________ “Cleanliness becomes more important as godliness becomes more unlikely.” O C D E T A I L S . C O M OCDETAILS BLOG Link to comment Share on other sites More sharing options...
