need bb Posted September 17, 2016 Share Posted September 17, 2016 I took a job in the Bay Area and I am debating on bringing my LGT. I have heard many stories about the difficult CA emissions, and I don't want to bring my car to then have to de-mod everything. If I bring my LGT will I need to change anything besides retuning for 91 octane? Below is my mod list: Kinugawa TD05-20GDW 850cc sidefeedsWalbro 255Grimmspeed TMICK&N TyphoonPerrin turbo inletGrimmspeed EBCSForge BPVGrimmspeed EWG UppipeCNT catted downpipeSPT Catback Thanks Link to comment Share on other sites More sharing options...
hadvw Posted September 17, 2016 Share Posted September 17, 2016 Congrats on the job. Tech related? Note: I'm not an expert, but I've gone through smog 3 or 4 times now. -non-OEM downpipe is most likely automatic fail, catted or not The other visible mods will tip off the inspector to look more closely. -if the turbo is noticeably different from OEM (for example, shiny, clearly says Kinugawa, etc) -not sure about TMIC - I've heard it MAY be allowed. -K&N -EBCS -BPV -Uppipe, if visible Note: I have gutted OEM pipes, and have always passed. I put on a CNT pipe + Grimmspeed TMIC this summer, but am planning to remove them for smog in the fall, then put back on after. They've never seen/complained about my DW 650s or Walbro - they don't look that far. But they do go under the car with a mirror to check for non-OEM pipes and/or missing cats. My BNR16 is one of the older ones that's in an original OEM VF40 housing, so it looks stock. Accessport and RomRaider tunes haven't been a problem, as long as the sensors are ready. That does sounds like a lot of stuff to remove. If you get lucky and the inspector doesn't notice the non-OEM turbo related stuff, then just putting stock pipes/heatshields/intake/TMIC back might do the trick. But it's not a given. Again, I'm not an expert, so wait to hear others' advice as well. Good luck! Link to comment Share on other sites More sharing options...
need bb Posted September 20, 2016 Author Share Posted September 20, 2016 Sounds like I minimally would need to get the stock DP Link to comment Share on other sites More sharing options...
Rhitter Posted September 20, 2016 Share Posted September 20, 2016 Stock DP and stock BPV. Anything else you can do to make your car appear stock is good to. Hide logos, etc. I passed with OEM BPV, DP, TMIC, and GS EBCS (kind of hidden) My OBXT build Link to comment Share on other sites More sharing options...
wesleyCrowbar Posted September 20, 2016 Share Posted September 20, 2016 I'm in a similar situation, albeit in Spring 2018. I still have the engine cover, an STI up pipe, and a shorty DP mated to the stock 2nd half of the OEM DP. How hard would they look at mine? Link to comment Share on other sites More sharing options...
Rhitter Posted September 20, 2016 Share Posted September 20, 2016 I'm in a similar situation, albeit in Spring 2018. I still have the engine cover, an STI up pipe, and a shorty DP mated to the stock 2nd half of the OEM DP. How hard would they look at mine? I think WRX USA passes with a similar set-up. Hard to say for sure though. My OBXT build Link to comment Share on other sites More sharing options...
wpmarky Posted September 21, 2016 Share Posted September 21, 2016 I passed with a cobb dp, oem CBE, oem tmic, oem bpv, stg 2 tune loaded via cobb ap. Link to comment Share on other sites More sharing options...
michael_c Posted September 22, 2016 Share Posted September 22, 2016 I passed with an AVO tmic (no engine cover), K&N typhoon, Greddy cat-back and OEM everything else. Link to comment Share on other sites More sharing options...
Scotty Posted September 24, 2016 Share Posted September 24, 2016 Intercoolers can be changed without an issue. It's everything else. I pass with a BNR turbo and an AVO uppipe, along with an AVO TMIC. I suggest going to a smog place in a strip mall at the busiest time possible, they are less thorough. Last time the guy did the visual from 3ft away from the engine compartment. Some of these independent places will be crawling around looking for everything. Link to comment Share on other sites More sharing options...
Rhitter Posted September 26, 2016 Share Posted September 26, 2016 That's a good point. One of the only times you don't want someone detailed oriented to look at your car. The TMIC seems fussy. Looking at the CA law books, I think it says - if the vehicle originally came with a TMIC you can replace the TMIC - as long as the BPV remains OEM. But, it's up to the Tech performing the visual. My OBXT build Link to comment Share on other sites More sharing options...
Boxerfxt Posted September 29, 2016 Share Posted September 29, 2016 I passed with an AVO tmic (no engine cover), K&N typhoon, Greddy cat-back and OEM everything else. please pm me the shop name if you would? Link to comment Share on other sites More sharing options...
