RHDsubaru Posted February 10, 2015 Share Posted February 10, 2015 When car idles good normal temp when in gear and brakes are on ,the temp gauge rises driving helps cool it down plz help the mailman Link to comment Share on other sites More sharing options...
monkeyposeur Posted February 10, 2015 Share Posted February 10, 2015 You might have air bubbles trapped in the coolant system. Purge the system a few times and see if that helps. Do you have and aftermarket thermostat? OEM subaru tstats are the only thermostat you should be using. Did you do any recent work on the car, drain the radiator, something along those lines? Link to comment Share on other sites More sharing options...
RHDsubaru Posted February 10, 2015 Author Share Posted February 10, 2015 Put in motor Link to comment Share on other sites More sharing options...
RHDsubaru Posted February 10, 2015 Author Share Posted February 10, 2015 Put in motorall new pump timing belt idlers and gears and gaskets. And Tstat All Link to comment Share on other sites More sharing options...
monkeyposeur Posted February 10, 2015 Share Posted February 10, 2015 Sounds like air trapped in the system to me then. Follow johnegg's guide: http://legacygt.com/forums/showthread.php/fill-and-burp-your-cooling-system-burpcoolingsystem-198487.html Link to comment Share on other sites More sharing options...
RHDsubaru Posted February 14, 2015 Author Share Posted February 14, 2015 When car idles good normal temp when in gear and brakes are on ,the temp gauge rises driving helps cool it down plz help the mailman now have no heat at all , not over heating but when it gets a little warm while driving slip tranny in neutral rev up 3 times temp goes down to normal. any advice ? Link to comment Share on other sites More sharing options...
RHDsubaru Posted February 15, 2015 Author Share Posted February 15, 2015 now I have no heat coming out of vent just cold air. cold postman :mad: Link to comment Share on other sites More sharing options...
monkeyposeur Posted February 16, 2015 Share Posted February 16, 2015 Take out the thermostat and your heat should come back. You can run it for a while like that. Did you replace the thermostat when you replaced the engine? Only use a Subaru thermostat. Link to comment Share on other sites More sharing options...
RHDsubaru Posted March 9, 2015 Author Share Posted March 9, 2015 Temp goes to almost hot comes back to norm goes almost to hot. New Subaru OEM t stat. Help Link to comment Share on other sites More sharing options...
