Redline2083 Posted May 20, 2012 Share Posted May 20, 2012 Hi fellas, i've recently been hearing this very loud sqeaky noise when my turbo is spooling which sometimes sounds like a loose belt. Between 1500rpm -2500rpm its there, once im over that engine speed iit stops. What could it be? It jus started happening out of the blue....Help plzz!! Its a jdm bl5 with the twinscroll turbo set up, not sure if that would help with any advice. Thanks Link to comment Share on other sites More sharing options...
fahr_side Posted May 20, 2012 Share Posted May 20, 2012 Look for a leaky up-pipe or the flanges / gaskets on either end. Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
Redline2083 Posted May 20, 2012 Author Share Posted May 20, 2012 Ok thanks...i'll check it out Link to comment Share on other sites More sharing options...
Redline2083 Posted May 20, 2012 Author Share Posted May 20, 2012 threw some soap water on the turbo and downpipe, theres a leak on the top of the downpipe right before the flange. Cud b my problem right there. Thanks alot bud Link to comment Share on other sites More sharing options...
