SneakyGT Posted May 29, 2015 Share Posted May 29, 2015 What a co-inkydink. Link to comment Share on other sites More sharing options...
Firepuma Posted June 24, 2015 Share Posted June 24, 2015 little pre sharknado photos Link to comment Share on other sites More sharing options...
lingling1337 Posted June 24, 2015 Share Posted June 24, 2015 Which rear end is that again? Looks awesome Link to comment Share on other sites More sharing options...
WRX USA Posted June 24, 2015 Share Posted June 24, 2015 Which rear end is that again? Looks awesome Blitzen rear bumper is on. I agree that it looks awesome! Link to comment Share on other sites More sharing options...
magnusonsubie Posted June 24, 2015 Share Posted June 24, 2015 I keep seeing Rev A-C front ends and I like them but I also like the Rev D-F. Such a tough decision of which one I want! 2005 Vader Wagon Material Tests on Ringland Failure Piston I should have held off and purchased a wagon instead of the spec.B Link to comment Share on other sites More sharing options...
LegacyDan Posted June 24, 2015 Share Posted June 24, 2015 Somebody buy those conversion kits! Do you ever see any of the front skirt extension for the spec b facelift bumper? I can't find the part number for it. http://i32.photobucket.com/albums/d3/desperatedano/0204401A20150213G00205.jpg I would say that and sti lip would look good. If they can both be used together. Link to comment Share on other sites More sharing options...
famaya26 Posted June 24, 2015 Share Posted June 24, 2015 I would assume because on the Pre facelift it is possible http://images.tapatalk-cdn.com/15/06/24/c37abd51bd93724cde71174b13bf0b69.jpg Sent from Señor Pug headquarters Link to comment Share on other sites More sharing options...
Bigshoes Posted June 25, 2015 Share Posted June 25, 2015 http://images.tapatalk-cdn.com/15/06/25/026098b32e2af0aacfd6d0ae46708075.jpghttp://images.tapatalk-cdn.com/15/06/25/a307735baff202096ba59be3f39a28a1.jpghttp://images.tapatalk-cdn.com/15/06/25/1ecf9984291a45ada50968f94de27665.jpg Few more piece and the front end gets swapped! Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
LegacyDan Posted June 25, 2015 Share Posted June 25, 2015 How does the rubber under lip attach to the sti lip? Link to comment Share on other sites More sharing options...
Bigshoes Posted June 25, 2015 Share Posted June 25, 2015 There's small push clips around the bottom of the lip. Similar to the ones that hold hood liner up. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
valleylegacy Posted June 25, 2015 Author Share Posted June 25, 2015 When you buy the STI Rubber Lip new, it comes with hardware and instructions on how to install it. Took me about 30 mins to do it perfectly with a razor blade to cut and a drill to make holes according to the diagram. Probably one of the best modifications to add to the STI LIP as it protects it and adds downforce. Plus it's genuine OEM. Link to comment Share on other sites More sharing options...
Firepuma Posted June 25, 2015 Share Posted June 25, 2015 bigshoes I've got parts if you need Link to comment Share on other sites More sharing options...
LegacyDan Posted July 7, 2015 Share Posted July 7, 2015 There's small push clips around the bottom of the lip. Similar to the ones that hold hood liner up. Sent from my iPhone using Tapatalk I got my rubber lip today from Japanparts, not the quality of product i was expecting for a genuine STI part, looks like some rubber trim you could find in your local hardware store! Link to comment Share on other sites More sharing options...
LegacyDan Posted July 8, 2015 Share Posted July 8, 2015 http://i32.photobucket.com/albums/d3/desperatedano/Mobile%20Uploads/IMG_20150708_201222.jpg Sizing it up and its too long so I guess you need to cut it to length going to be difficult to get a nice clean edge when cutting it Link to comment Share on other sites More sharing options...
valleylegacy Posted July 9, 2015 Author Share Posted July 9, 2015 yes you need to cut it. I used a razor blade to even make the cuts, allowing the lip to bend as you shape it to the STI lip. Took me 20 mins to install. Including using a drill with a proper sized bit to make holes. Space the holes as evenly as possible too. Link to comment Share on other sites More sharing options...
LegacyDan Posted July 10, 2015 Share Posted July 10, 2015 I cannot figure out these diagrams. Do I only need to cut the ends or make diagonal cuts where it bends at the corners? http://i32.photobucket.com/albums/d3/desperatedano/Mobile%20Uploads/IMG_20150710_160725.jpg http://i32.photobucket.com/albums/d3/desperatedano/Mobile%20Uploads/IMG_20150710_160742.jpg 5.2 shows some weird triangle shapes! Link to comment Share on other sites More sharing options...
valleylegacy Posted July 11, 2015 Author Share Posted July 11, 2015 make triangle shaped cuts where the lip should bend. Link to comment Share on other sites More sharing options...
WinstonSmith Posted July 11, 2015 Share Posted July 11, 2015 http://images.tapatalk-cdn.com/15/06/25/026098b32e2af0aacfd6d0ae46708075.jpg Forgive my ignorance, I am to the legacy world. Other than the License plate bracket, what is the difference from the USDM bumper? Link to comment Share on other sites More sharing options...
LegacyDan Posted July 11, 2015 Share Posted July 11, 2015 make triangle shaped cuts where the lip should bend. Yep i got it fitted eventually, triangle cuts really help a lot, ill get it fitted up to the car tomorrow. It really finishes off the STI lip well. I just hope it holds up over the ramps and inclines Link to comment Share on other sites More sharing options...
Hanger Posted August 7, 2015 Share Posted August 7, 2015 BEHOLD! My 2nd Legacy with JDM conversion! :wub: ○ ○ ○ Instagram: itshangertime :spin: ○ ○ ○ Link to comment Share on other sites More sharing options...
Drift Motion Posted August 7, 2015 Share Posted August 7, 2015 pin strip huh did they pay you to advertise for them? Link to comment Share on other sites More sharing options...
Hanger Posted August 7, 2015 Share Posted August 7, 2015 No, I paid for the pinstripe. License plate frames were free ○ ○ ○ Instagram: itshangertime :spin: ○ ○ ○ Link to comment Share on other sites More sharing options...
lingling1337 Posted August 8, 2015 Share Posted August 8, 2015 Like it or not the pinstripe is a super jdm look Link to comment Share on other sites More sharing options...
Hanger Posted August 8, 2015 Share Posted August 8, 2015 Like it or not the pinstripe is a super jdm look I love it! [emoji7] ○ ○ ○ Instagram: itshangertime :spin: ○ ○ ○ Link to comment Share on other sites More sharing options...
Drift Motion Posted August 14, 2015 Share Posted August 14, 2015 No, I paid for the pinstripe. License plate frames were free If you paid for that, then why the hell did they write their name on your car? I'd never advertise for someone else for free Link to comment Share on other sites More sharing options...
