canis Posted March 4, 2007 Share Posted March 4, 2007 I just changed my sparkplugs. Started the car, and it was shaking badly and threw a CEL. Cylinder 2 and 3 misfire. Which ones are cylinders 2 and 3? I guess I might have banged the plugs going in and threw off the gap or something... Link to comment Share on other sites More sharing options...
sutter2k Posted March 4, 2007 Share Posted March 4, 2007 Was the engine hot when you changed them? Link to comment Share on other sites More sharing options...
bmorrisj Posted March 4, 2007 Share Posted March 4, 2007 sitting in the drivers seat ftont 21 43 rear Link to comment Share on other sites More sharing options...
canis Posted March 4, 2007 Author Share Posted March 4, 2007 Thanks. Nope, the engine was cold. Link to comment Share on other sites More sharing options...
Prime Power Posted March 4, 2007 Share Posted March 4, 2007 What brand of plugs out of curiosity? Link to comment Share on other sites More sharing options...
canis Posted March 4, 2007 Author Share Posted March 4, 2007 The factory plugs - NGK laser iridium (same part numbers as the plugs I removed). Link to comment Share on other sites More sharing options...
mccorry Posted March 4, 2007 Share Posted March 4, 2007 Are you sure you didn't accidentially switch coils (ie firing order)? Link to comment Share on other sites More sharing options...
REM87O Posted March 4, 2007 Share Posted March 4, 2007 Are you sure you didn't accidentially switch coils (ie firing order)? Is there enough length in the wires to even do this by mistake? If there is, this would be my first guess also since canis said "shaking" and the firing order is screwed up. Link to comment Share on other sites More sharing options...
MDW25gt Posted March 4, 2007 Share Posted March 4, 2007 Is there enough length in the wires to even do this by mistake? If there is, this would be my first guess also since canis said "shaking" and the firing order is screwed up. Might be enough length, but the check should be that the wires do not cross over each other. On mine the wires go directly to the nearest plug. Or said another way the relative position of the 4 coils is the same as the plug position it goes to. Link to comment Share on other sites More sharing options...
mccorry Posted March 4, 2007 Share Posted March 4, 2007 Is there enough length in the wires to even do this by mistake? I dunno... but it sure sounds like a firing order issue to me. Link to comment Share on other sites More sharing options...
canis Posted March 5, 2007 Author Share Posted March 5, 2007 Doh! Cylinder 3 coil wire had come loose! Car no longer shakes. Still throwing a cylinder 2 misfire code though. If cylinder 3 wasn't plugged in, would the computer do something to cylinder 2 to compensate? Because the plug (brand new) in cylinder 2 is black. Link to comment Share on other sites More sharing options...
Prime Power Posted March 5, 2007 Share Posted March 5, 2007 Do a reset and try again. Disconnect negative and pump brakes. Good luck. Link to comment Share on other sites More sharing options...
mccorry Posted March 5, 2007 Share Posted March 5, 2007 Yeah... your misfire in 3 would've made the O2 sensor read all screwy.... The other cylinder probably got fattened up (richer) to try and compensate. Id clear it and go clean everyting out with a spirited drive. Link to comment Share on other sites More sharing options...
canis Posted March 5, 2007 Author Share Posted March 5, 2007 Thanks guys. After plugging in the cylinder 3 coil, waiting 10 min, then starting it and letting it idle for 10 min, I took a short drive to make sure the cylinders were cleared out, and then disconnected the battery for 30 min. I've driven over 20 miles since, and no CEL! Link to comment Share on other sites More sharing options...
Prime Power Posted March 5, 2007 Share Posted March 5, 2007 great to hear it. Link to comment Share on other sites More sharing options...
Beanboy Posted March 7, 2007 Share Posted March 7, 2007 Good jorb! Doing spark plugs when the time comes doesn't seem all that fun on a turbo flat four versus an inline four. Not looking forward to it! 60K is it? -B http://www.standardshift.com Link to comment Share on other sites More sharing options...
bmorrisj Posted March 7, 2007 Share Posted March 7, 2007 Good jorb! you done a great jaerb! Link to comment Share on other sites More sharing options...
canis Posted March 7, 2007 Author Share Posted March 7, 2007 It's 60k in the regular maintenance schedule, but that is +/- depending on your driving habits. Mine started throwing misfires and 02 codes at 35k! Link to comment Share on other sites More sharing options...
lvethesnow Posted March 7, 2007 Share Posted March 7, 2007 i dont know about you guys but when ever i change my spark plugs i do one at a time. that way there are no problems trying to figure out what wire goes to what cylinder. espically on my 06 charger r/t it has 16 spark plugs History does not entrust the care of freedom to the weak or timid People sleep peacefully at night cause rough men stand ready to do violence on there behalf Link to comment Share on other sites More sharing options...
