mdzowner Posted May 27, 2015 Share Posted May 27, 2015 anyone have any experience with un-seizing a caliper? ive looked at a few you tube videos but im not totally sold on the idea of trying myself Link to comment Share on other sites More sharing options...
whitetiger Posted May 27, 2015 Share Posted May 27, 2015 What is seized? the slide pins or the piston? Link to comment Share on other sites More sharing options...
Silinc3r Posted May 27, 2015 Share Posted May 27, 2015 You can lift the caliper up and have someone gently push on teh brake to extend the piston. Then try and push the caliper back in with a clamp. If the outer dust boot on the piston is bad chances are the psiton has rust and the inner, square cut seal is bad as well. They are difficult to rebuild just takes a little time your first try. But yes, if it is just the guide pins. Clean them and relube them Silinc3r's 05 SWP GT/Spec B Link to comment Share on other sites More sharing options...
mdzowner Posted May 28, 2015 Author Share Posted May 28, 2015 thanks for the heads up. turns out it was the piston. i sprayed the crap out of it with brake cleaner for about an hour and then with a board cut to look like a brake pad i clamped it with a c clamp to push it back in. it worked pretty well. it did have a crap load of rust and brake dust deposit all over it. the seals looked to be in decent shape so we will see. Link to comment Share on other sites More sharing options...
Silinc3r Posted May 29, 2015 Share Posted May 29, 2015 Wait so did you pull the piston out? If the rust is just on the inside of the piston or on the face of the piston that is ok, normal. But if it is the square cut seal, which can not be seen unless the piston is pulled out. If that is bad and the piston is rusted where it sits inside the bore of the caliper it will keep seizing. Silinc3r's 05 SWP GT/Spec B Link to comment Share on other sites More sharing options...
mdzowner Posted May 29, 2015 Author Share Posted May 29, 2015 did not pull the piston out. i depressed the brake to extend both pistons and clamped them back in it seemed to be sliding in and out as normal. perhaps im not doing it correctly to verify? Link to comment Share on other sites More sharing options...
Silinc3r Posted June 5, 2015 Share Posted June 5, 2015 No, that is a good way to check the operation. While you're at it, I would change the fluid as well. So are they working better now? Silinc3r's 05 SWP GT/Spec B Link to comment Share on other sites More sharing options...
NewJerseyDevil Posted June 8, 2015 Share Posted June 8, 2015 Update? Link to comment Share on other sites More sharing options...
