What size hubcentric rings?
scoobydoobie
According to this:
http://www.summitracing.com/parts/DGW-49260/
those come with a 73mm bore, so 73 -> 56.1. Somebody correct me if I'm wrong.
Thanks for the info.
typical aftermarket wheels are 73.1mm or 74.1mm depending on bolt pattern
but you won't need those rings if you install the wheels correctly
You sure? Both the vendor and people in "The Drag Wheels Thread" on NASIOC say you need hub rings to run them.
Also OEM lugs won't work either from what I've read.
If you have conical seat lug nuts, you won't need the rings, just remember to tighten them evenly and gently.
what he said...
wobble the wheel as you tighten down the lug nuts
"requiring" the rings is just a way for the vendor to not take responsibility/hassle of dealing with vibration in the wheel
only reason why the stock lug nuts won't work is because they are too big to fit into the wheel's lug hole, otherwise our stock lug nuts are conical...
