XxKylexX Posted December 28, 2012 Share Posted December 28, 2012 Anyone got any pictures of there fog light set up and switches? Post pictures here or comments! I want something besides the OEM switch but idk what will fit! Link to comment Share on other sites More sharing options...
subikid90 Posted December 28, 2012 Share Posted December 28, 2012 I do not have a picture but I put two switches below the ashtray/acc outlet on the vertical part of the shifter trim. Looks almost factory. If I remember I can snap a picture of them. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
monkeyposeur Posted December 28, 2012 Share Posted December 28, 2012 I've spent many days trying to figure out how to use an OEM switch for completely independent fog lights. The OEM switch has six pins and five wires coming out of the harness plug. I can't figure it out. I know how to wire the OEM switch to function stock, but that is not my goal. Tomorrow I will try to wire them in with a rocker switch and a relay so they will be completely independent. BTW if anyone knows how to get the OEM switch to work in this respect I'm all ears. I'm sure it has to be possible but I'm at a loss. I'm going to sleep on it and see if I wake up with any ideas. Link to comment Share on other sites More sharing options...
XxKylexX Posted December 28, 2012 Author Share Posted December 28, 2012 I was looking at jet switches to put in mine but idk if they will Even be close to fitting haha I want it though Link to comment Share on other sites More sharing options...
twisty Posted December 28, 2012 Share Posted December 28, 2012 i use these for most of my internal switching needs. i drill and fit them into factory blanks when i can, they look nice. http://www.bizrice.com/upload/20120309/FL3_18_lighted_round_rocker_switch.jpg Link to comment Share on other sites More sharing options...
ehsnils Posted December 28, 2012 Share Posted December 28, 2012 Here's mine (a bit dusty...): http://www.bedug.com/pics/Subaru/stalk.jpg Link to comment Share on other sites More sharing options...
Kiyo1990 Posted December 28, 2012 Share Posted December 28, 2012 http://i410.photobucket.com/albums/pp185/toyotaman15/Subaru%20Legacy/C0EC2B0E-FE67-48D3-BE09-B1EB31DD10C7-1504-000000B63533C733.jpg Could have done a better area, but heres where I put mine Link to comment Share on other sites More sharing options...
Stang70Fastback Posted December 29, 2012 Share Posted December 29, 2012 Here's mine (a bit dusty...): http://www.bedug.com/pics/Subaru/stalk.jpg Where did you get that stalk? Link to comment Share on other sites More sharing options...
XxKylexX Posted December 29, 2012 Author Share Posted December 29, 2012 Here's mine (a bit dusty...): http://www.bedug.com/pics/Subaru/stalk.jpg That's pretty sick. I wanted to replace my Pre cut outs (like where the cruise control and rear defrost are) on the left side but idk if some of the switches will fit it. I really like this look you got! Link to comment Share on other sites More sharing options...
Joaks Posted December 29, 2012 Share Posted December 29, 2012 I have an OEM switch and OEM fog lights which are independant of the headlights. I did not use the OEM wiring harness and instead a regular relay (parking lights need to be on with me setup). Link to comment Share on other sites More sharing options...
Michalooch Posted December 30, 2012 Share Posted December 30, 2012 How do I get JUST my parking lights and foglights on without headlights? Link to comment Share on other sites More sharing options...
stevenva Posted December 30, 2012 Share Posted December 30, 2012 Have you ever considered using a capacitive touch kit instead of a switch? You won't need to modify your dash. You can install it so that a chosen metal part you touch activates the device, like a semi-hidden screw, ect. This is a dual circuit kit that will drive 2 separate devices if you want. Relays will be required but you will need relays anyway for all but the most robust switches. [ame=http://www.amazon.com/Ramsey-TS1-Touch-Switch-Sensor/dp/B0002NRLHU]http://www.amazon.com/Ramsey-TS1-Touch-Switch-Sensor/dp/B0002NRLHU[/ame] RIP 96 Legacy 2.2 4EAT lost reverse @ 374,000 miles Link to comment Share on other sites More sharing options...
Stang70Fastback Posted December 30, 2012 Share Posted December 30, 2012 Lol, too bad our cars' interiors are just a vast expanse of black plastic with almost no metal materials. Cool idea tho. Then you can tell everyone your car works just like the new Cadillac Cue system! Link to comment Share on other sites More sharing options...
stevenva Posted December 30, 2012 Share Posted December 30, 2012 In that case you can use a this device. It is designed to be placed behind any non-conductive surface for activation. No physical contact is needed. http://www.bonanza.com/listings/Electronic-Kit-Capacitive-Touch-Sensor-Switch-12V/39831914?gpid=21297750541&gpkwd=&goog_pla=1&gclid=COH9nOvlwrQCFQqk4AodTiQAOA RIP 96 Legacy 2.2 4EAT lost reverse @ 374,000 miles Link to comment Share on other sites More sharing options...
