rob-2 Posted July 5, 2014 Share Posted July 5, 2014 It seems I'm leaking oil off the base of the turbo where the return line connects. Is there a way to tight this connection up without removal of the turbo? I've already re-tightened the turbo strap and the intake lines. So I'm at a loss for where this leak is but from this line. Thoughts? As for the amount of oil it's leaking, it's not a steady flow, but rather a drip. I have oil under the car where ever I park. Would like this to stop. Pretty much at my whits end with this car. Link to comment Share on other sites More sharing options...
firehawk618 Posted July 6, 2014 Share Posted July 6, 2014 I had this same issue after my turbo swap. I used worm gear clamps on both ends. I found both 10mm bolts were loose. I finnagled an assortment of sockets, swivels, extensions etc up in there and got it snug. Seems my leaks are finally gone..... 10' CTS-V, A6, Airraid, 2.4 upper, ID850's, self tuned. SOLD:06' LGT Wagon. BNR16G, Catless UP, DOWN, Hexmods VB, Hexmods diff bushings, BIG TMIC. Best 0-60: 4.651 by AP 1/4= 13.678@100.73 mph, 1.945 60', Automatic transmission. Link to comment Share on other sites More sharing options...
rob-2 Posted July 6, 2014 Author Share Posted July 6, 2014 Got the worm clamps on there but now to get up there and tighten up those bolts. Link to comment Share on other sites More sharing options...
rob-2 Posted July 6, 2014 Author Share Posted July 6, 2014 Did you drop any of the pipes? Link to comment Share on other sites More sharing options...
Canonguy Posted July 7, 2014 Share Posted July 7, 2014 Much easier to get to the oil return line clamps if you drop the down pipe. Still a PITA but helps. Link to comment Share on other sites More sharing options...
Max Capacity Posted July 7, 2014 Share Posted July 7, 2014 How old is that hose ? They don't last forever... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
rob-2 Posted July 7, 2014 Author Share Posted July 7, 2014 new hose and turbo Link to comment Share on other sites More sharing options...
sbw Posted July 7, 2014 Share Posted July 7, 2014 To me, that looks like the gasket for the hard return line that bolts to the bottom of the CHRA. You're not replacing that gasket without removing the turbo. You might, emphasis on might, be able to get at it if you have access to a lift and remove your downpipe without removing the turbo. Link to comment Share on other sites More sharing options...
Max Capacity Posted July 7, 2014 Share Posted July 7, 2014 Looks like a install error... wasn't it tight when it was put in ? Sorry to give you crap... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
AMileHighLGT Posted July 7, 2014 Share Posted July 7, 2014 I have been able to get to the two bolts with a 2 ft 1/4" extension and a 10mm 1/4" snap on wobble socket while the vehicle is on a lift. Link to comment Share on other sites More sharing options...
rob-2 Posted July 7, 2014 Author Share Posted July 7, 2014 I don't think I will be fixing this. Car just nearly overheated on teh freeway. It's always something... I think I'm going down to the dealership to trade it in. Effing POS. Thanks guys for your feedback and help. Link to comment Share on other sites More sharing options...
rob-2 Posted July 8, 2014 Author Share Posted July 8, 2014 Looks like a install error... wasn't it tight when it was put in ? Sorry to give you crap... I didn't install it shop did while I was traveling. My life is crazy right now. We are buying a Lexus IS this week and being done with this car. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted July 8, 2014 Moderators Share Posted July 8, 2014 I didn't install it shop did while I was traveling. My life is crazy right now. We are buying a Lexus IS this week and being done with this car. Can't blame you, your car seems to be cursed "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Tehnation Posted July 8, 2014 Share Posted July 8, 2014 Did you get a new oil return stem or resurface the old one? The part that bolts to the turbo. I had a pita time with my new turbo, I thought it was the hose, but the oil stem had warped on the old turbo and did not make a proper seal with the turbo. From the picture it looks like your oil stem is leaking not the hose because the oil is at the top. If that's the case you HAVE to pull the turbo to get the coolant lines out of the way to get to the bolts. Make sure to use new gaskets and new stem. Link to comment Share on other sites More sharing options...
rob-2 Posted July 8, 2014 Author Share Posted July 8, 2014 Did you get a new oil return stem or resurface the old one? The part that bolts to the turbo. I had a pita time with my new turbo, I thought it was the hose, but the oil stem had warped on the old turbo and did not make a proper seal with the turbo. From the picture it looks like your oil stem is leaking not the hose because the oil is at the top. If that's the case you HAVE to pull the turbo to get the coolant lines out of the way to get to the bolts. Make sure to use new gaskets and new stem. I don't know. See I didn't do the work and the shop closed up 2 weeks ish after the service was done. Either way the car is going bye-bye it's been the biggest pile of crap car I've ever owned. Learned my lesson. Never waste your money rebuilding a motor. This car was to go another 50-60k, it's at 118 now. Last summer dropped $6k on motor. Just dropped money on new tires, turbo etc. I'll never touch another Subaru again. I checked the coolant, it's not low. So no valid reason why it overheated. Sadly I actually enjoyed the look and drive of the car these last 6 months. They're just too difficult to work on and too poorly designed to keep as a primary car. Link to comment Share on other sites More sharing options...
