Ben450 Posted December 8, 2012 Share Posted December 8, 2012 I want to be lowest that's possible. It's rubs nowhere in the fenders. I have rota 18x9.5.This winter I'll pull and roll my fender. I have 450hp I need a really stiff suspension http://img.tapatalk.com/d/12/12/08/tu8eneja.jpg Ben Link to comment Share on other sites More sharing options...
EJ25subie05 Posted December 8, 2012 Share Posted December 8, 2012 search is your best friend, no one knows what your doing with the car. your description is so vague that you could be doing autox to being a stance car. do research and find the right suspension upgrade for your application. there are many coil overs tein, bc, RCE, kw, racecomp etc... also i would like to see more pics of your car and a mod list if possible cars looking good so far Link to comment Share on other sites More sharing options...
Ben450 Posted December 8, 2012 Author Share Posted December 8, 2012 I want a set up same with this http://img.tapatalk.com/d/12/12/08/y5e3yja6.jpg Ben Link to comment Share on other sites More sharing options...
SVT2LGT Posted December 9, 2012 Share Posted December 9, 2012 Here's mine set about 3/4's down (still lots more drop available with these coilovers) Aaron http://i300.photobucket.com/albums/nn22/svtsnob/Legacy%20GT/IMG_1148.jpg Link to comment Share on other sites More sharing options...
angeltalin Posted December 9, 2012 Share Posted December 9, 2012 more pics of your car and a mod list if possible cars looking good so far StageIII Cryotune-Kinugawa STS TD06H-20GTX 9 blade turbine, ID1000, DW65c, 73mm MegaMAF , GS EWG up-pipe, Downpipe and EBCS, FMS FMIC, TGV Delete, Brembo swap Link to comment Share on other sites More sharing options...
Ben450 Posted December 9, 2012 Author Share Posted December 9, 2012 http://img.tapatalk.com/d/12/12/10/nu5y5u3a.jpg http://img.tapatalk.com/d/12/12/10/y4agapan.jpg http://img.tapatalk.com/d/12/12/10/ytemy6ys.jpg Engine: Mahle piston Eagle rods Cosworth rod bearing Cosworth crank bearing Cam BC 280 deatschwerks injectors 850cc AVO 450 turbo Egal headers Clutch bully stage 4 Lightweight crank pulley Perrin cold air Big fmic (I don't no the name) 6speeds sti 05 Pro DCCD Suspension: Ksport pro kontrol coilover Witeline rear camber bushing Rota grid 18x9.5 flat black Falken f452 224/40/18 Front and rear Brembo Ben Link to comment Share on other sites More sharing options...
Drift Motion Posted December 10, 2012 Share Posted December 10, 2012 if you have 450hp, you should get some better tires than the FK452s you can easily slam the car with that tire/wheel spec, just roll the fenders flat Link to comment Share on other sites More sharing options...
robitrice Posted December 10, 2012 Share Posted December 10, 2012 holy huge fmic!!!! great looking car tho Link to comment Share on other sites More sharing options...
