Backup lights
Quick question on my backup lights.
I have. An 05 XT limited, MT. With backup lights not working.
Bulbs are ok, Backup fuse is ok,
Located the backup (and neutral switch) and tested. I figured if I shorted the wires coming into the switch The lights would come on but they didn't...this surprised me. Also the switch does not appear to close when I test across it.
What am I missing! I would think that shorting the leads would bypass the switch.
Open the hatch in the upper right corner that is a rubber cover around the wires. If you pull that back a bit you'll see the wires inside it.
I just had my buddies body shop fix 4 broken wires there and repair the other ones that were cracked for like $120.00
My rear wiper wasn't working correctly.
Engine Build - Click Here
I won't start tearing things up, just pull the rubber cover back and check the condition of the wires. If you have broken or cracked wires, then there may be a issue.
When you see the tighness of the area, you'll find a good body shop and have them do the work. My buddies shop is mainly a restoration shop but does all body work the help pay the bills.
When I asked a friend at the parts counter at the Subaru dealer he said they get a few of these cars in a with borken wires in that spot. It's $3-400 to fix it.
If you can, on page 4572 in the 05 service manual is how to remove the back up light.
