dawkins20 Posted June 11, 2013 Share Posted June 11, 2013 Is there any reason why I couldn't just open the airbox, remove the air filter and then spray the MAF with the aerosol MAF cleaner rather than have to unscrew the sensor and remove it? I was concerned about damaging the O ring and wondered if this method would work instead. Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted June 11, 2013 Mega Users Share Posted June 11, 2013 You have to spray into the sensor, so most likely you won't clean it properly. Just be careful with the o ring and it will take you all of 5 minutes if you're slow. Link to comment Share on other sites More sharing options...
