Lojasmo Posted June 1, 2011 Share Posted June 1, 2011 Second generation. 5mt. AWD. Happens mostly at low speeds, mostly when turning. I suspect the steering rack bushings, but lots of bushings may need to be replaced. Consider this a game. And yes, I have read the sticky. List, in order, the parts you would replace. Source and part number will earn you one Internet. Link to comment Share on other sites More sharing options...
subikid90 Posted June 2, 2011 Share Posted June 2, 2011 Could be sway bar bushings. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
Lojasmo Posted June 2, 2011 Author Share Posted June 2, 2011 Could be sway bar bushings. Agreed. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted June 2, 2011 I Donated Share Posted June 2, 2011 sway bar bushings steering rack bushings control arm bushings strut mounts (top hats) I would as well shake down the front end to make sure your lower ball joints and outer tie rod ends are in good shape. I was thinking about buyings this bushing kit for my own car. Its for an Impreza, but I believe most of the bushings will fit on our cars. When you replace bushings, make sure you grease them up or else they will make all kinds of funny noises Can I have two internets because I linked you to an all in one kit? haha -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
meier motor sports Posted June 2, 2011 Share Posted June 2, 2011 i would not replace anything until i diagnosed Link to comment Share on other sites More sharing options...
Lojasmo Posted June 2, 2011 Author Share Posted June 2, 2011 sway bar bushings steering rack bushings control arm bushings strut mounts (top hats) I would as well shake down the front end to make sure your lower ball joints and outer tie rod ends are in good shape. I was thinking about buyings this bushing kit Can I have two internets because I linked you to an all in one kit? haha Yes, two internetz to you, sir. one more if you get it, and post a thread about how it fits. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted June 3, 2011 I Donated Share Posted June 3, 2011 lol. Most of the suspension parts between the Legacy and WRX are interchangable. I don't think EVERYTHING in the kit will fit, but most of it should -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Lojasmo Posted June 4, 2011 Author Share Posted June 4, 2011 Well, it isn't the strut mounts. Link to comment Share on other sites More sharing options...
