00transamnh Posted February 26, 2013 Share Posted February 26, 2013 The long and short: Replacing a blown turbo. Got new oem oil hard lines (and banjo bolts) with the turbo. HOW THE HELL DO I INSTALL THIS THING? Is there some trick I am not seeing? Currently the turbo is out of the car. Do I need to pull the intake manifold to get the line in place? Link to comment Share on other sites More sharing options...
mr.hicksta Posted February 26, 2013 Share Posted February 26, 2013 Simply put, it's an absolute PITA to install. There's a water pipe that crosses over the corner of the AVCS line as well, which essentially makes it mandatory to remove so you can swap them out. Link to comment Share on other sites More sharing options...
00transamnh Posted February 26, 2013 Author Share Posted February 26, 2013 Simply put, it's an absolute PITA to install. There's a water pipe that crosses over the corner of the AVCS line as well, which essentially makes it mandatory to remove so you can swap them out. Thanks for the help. Sometimes I question the layout of this engine... Link to comment Share on other sites More sharing options...
00transamnh Posted February 26, 2013 Author Share Posted February 26, 2013 No way in hell. I dont see how its possible without pulling everything off the top of the engine. Maybe I am better off next day airing some flex oil lines. Link to comment Share on other sites More sharing options...
mr.hicksta Posted February 26, 2013 Share Posted February 26, 2013 Yeah, the IP&T filtered oil supply line is the way to go. Hit up m sprank and assuming he has them in stock he should be able to get one out to you fast. Link to comment Share on other sites More sharing options...
00transamnh Posted February 26, 2013 Author Share Posted February 26, 2013 What a bitch. Whoever designed all the external routing for this engine is a complete dink. Link to comment Share on other sites More sharing options...
00transamnh Posted February 26, 2013 Author Share Posted February 26, 2013 The IP&T oil supply line is ridiculously expensive... It will cost me $300 to next day the package. Looks like I will be pulling the intake manifold off tomorrow. Link to comment Share on other sites More sharing options...
Max Capacity Posted February 26, 2013 Share Posted February 26, 2013 You'll also want to make sure you tighten all the gas line clamps while the intake is off. They have been known to leak when its cold out. Here's a picture. http://i185.photobucket.com/albums/x40/92Si/DSCN4749.jpg You should replace the seals where the TGV's meet the heads too. Not sure if auto parts stores have those. Have you replaced the orange o-rings between the intake and TGV's yet also ? here's another for reference http://i185.photobucket.com/albums/x40/92Si/DSCN4769.jpg A lot of us leave the filter out of that banjo bolt. I have both mine removed. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
00transamnh Posted February 26, 2013 Author Share Posted February 26, 2013 So I will need two sets of gaskets right? The one between the head and the TGV and the one between the TGV and the manifold...? This project just turned into such a F****** B****. Link to comment Share on other sites More sharing options...
Max Capacity Posted February 26, 2013 Share Posted February 26, 2013 Yes, When I did my o-rings it was a PITA to lift just one side of the manifold enough to slip the old out, etc... When I removed the manifold for the engine rebuild, I unbolted the TGV's to heads, I think there was one other bolt under the manifold but it was easier to lift the intake off the block that way. When you see the old black o-rings next to the new larger orange ones you'll understand why they leak. Take your time, zip tie all the vacuum lines after wards, you can do this. You'll enjoy the vacation pic's I sent you. THe GT engines start around page 1600. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Mega Users paintpollz Posted February 26, 2013 Mega Users Share Posted February 26, 2013 Yes, When I did my o-rings it was a PITA to lift just one side of the manifold enough to slip the old out, etc... The drivers side closest to the firewall. Like Max said, just take your time. It is VERY helpful to have an inspection mirror to make sure all of the rings are properly set. I ran into a lot of trouble with this. "Remember Danny - Two wrongs don't make a right but three rights make a left." Link to comment Share on other sites More sharing options...
V8Bait Posted February 26, 2013 Share Posted February 26, 2013 Have any of you installed the FP AVCS oil line without any fitment issues? Link to comment Share on other sites More sharing options...
00transamnh Posted February 26, 2013 Author Share Posted February 26, 2013 I am not trying to turn this into a bitching session but I just ran into another issue and I really need to vent. Why do they have a screened banjo bolt behind the timing cover! Seriously!? So, anyone that wants to check the screen in that thing needs to pull the front timing covers, pull the belt, pull the cam sprocket, pull the rear cover, and only THEN can they pull it. Unreal. Clearly the designer of the external routing of this engine never wrenched on anything in their lives. PS I just did the timing belt 100 miles ago... Ugh. Time to get back to work. Link to comment Share on other sites More sharing options...
Max Capacity Posted February 26, 2013 Share Posted February 26, 2013 You can file the top off the bolt and remove it with the cover in place. That's what HAMMERDOWN did, he has a DIY thread here somewhere. PM him for the link. It sounds like you have a clue and know how to work on your own car, think about, you can figure it out. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
00transamnh Posted February 27, 2013 Author Share Posted February 27, 2013 Yeah I came across his post for that yesterday. I will definitely be using his method to pull the banjo. Link to comment Share on other sites More sharing options...
CoolHandLuke12 Posted March 15, 2013 Share Posted March 15, 2013 hey running into this as we speak, pretty much going to cut the old oil supply line, but yeah have the slightest clue on how to get the new oil supply line on..any pictures or comments on what can be done? dont wanna spend another $200 on the stainless lines, even though it might be an easier route... Link to comment Share on other sites More sharing options...
Dvour Posted March 16, 2013 Share Posted March 16, 2013 Did you get the p0011 and p0021 code before your turbo blew? I have bothvthose codes and im trying to prevent getting a whole new turbo Link to comment Share on other sites More sharing options...
CoolHandLuke12 Posted March 16, 2013 Share Posted March 16, 2013 no i had a p0172, never the other two tho Link to comment Share on other sites More sharing options...
