garageboy Posted September 7, 2015 Share Posted September 7, 2015 Just bought an 05 Legacy. While test driving, I did sharp turns at low speed and had no handling or noise problems. This is while going forward. Today my son backed out of a parking place at low speed, cut the wheel hard, and it started making a squealing noise while the wheel was turned. He did not notice any vibration. Previous owner said it needs a rear strut replaced. Could this be the cause of the noise? Thank you. Link to comment Share on other sites More sharing options...
Mr. Sinister Posted September 7, 2015 Share Posted September 7, 2015 My guess would be worn brake pads. Link to comment Share on other sites More sharing options...
garageboy Posted September 7, 2015 Author Share Posted September 7, 2015 Thank you, Mr. Sinister. Link to comment Share on other sites More sharing options...
MaasaiWarrior Posted September 8, 2015 Share Posted September 8, 2015 Could be your power steering belt, mine squeals every so often at full lock 08 Spec B, insta: @08_spec_b, 10 SH Forester insta: @shfozzy Link to comment Share on other sites More sharing options...
apexi Posted September 8, 2015 Share Posted September 8, 2015 Yeah, my steering gets a little noisy when I cut the wheel hard while backing up if the car is cold. No problems once everything gets warmed up. Link to comment Share on other sites More sharing options...
Joseph Bobby Posted September 8, 2015 Share Posted September 8, 2015 Yes, you need to replace the struts in your car. It is necessary to replace the struts because it helps to control the stability of the vehicle. I would recommend you to replace the struts in pairs. Here at Edmonton, auto repair centers like http://www.apexspecialized.ca offers this service. Link to comment Share on other sites More sharing options...
5thElement Posted September 8, 2015 Share Posted September 8, 2015 It is not recmended to turn your wheel to full lock most cars don't like this and will cause the pump or belt to make the squealing noise. Try to to turn to full lock position and check the fluid level and belt condition and tension. Link to comment Share on other sites More sharing options...
5th Earth Posted September 13, 2015 Share Posted September 13, 2015 Where does the noise come from? If it's coming from the front it's obviously not the rear struts. My first guess would be the power steering belt, or something else in the power steering system. If it's from the back, next guess would be brakes. You can test by doing stuff in reverse and seeing if it only happens when the brakes are on. If it's the brakes and it only happens while reversing, you probably don't even need to change anything. Some cars just have brake squeal when while backing up because it puts more load on the smaller rear brakes, and in an unusual direction. Just look at the pads and see if they still have good thickness, and see if the rotors look okay. If they check out, it's just brake squeal. It shouldn't affect your performance appreciably, but if you want to fix it some brake pad grease and/or new backing pads may help. Link to comment Share on other sites More sharing options...
battelready Posted September 15, 2015 Share Posted September 15, 2015 ^^ Yep, my brembos squeal backing up. I bought an auto be more involved in my uninvolvedness . 200k+ Club If you can't blind them with brilliance, baffle them with bullshit. My high mileage turd. Link to comment Share on other sites More sharing options...
garageboy Posted September 16, 2015 Author Share Posted September 16, 2015 Thank you very much MaasaiWarrior , apexi, Joseph Bobby ,5thElement , and 5th Earth! Link to comment Share on other sites More sharing options...
Hoojammyflip Posted September 21, 2015 Share Posted September 21, 2015 ^^ Yep, my brembos squeal backing up. Mine too... Link to comment Share on other sites More sharing options...
