bettner12 Posted November 25, 2013 Share Posted November 25, 2013 Event: dyno pull Location: Innovative Tuning, Buffalo NY Ambient Temp: 48 degrees fahrenheit Elevation: 620 feet above sea level Weather: wet Tires: Crusade HP (yes, I said CRUSADE - I never heard of them either) on Forgestar F14's Car: 2005 Subaru Forester XTi Tuner: Mike @ Innovative Tuning Dyno Info: Mustang AWD dyno Transmission: 5 speed Subaru gearset with Moore Performance BlastPlates Gear: 3rd Peak HP at RPM: 622@7600 Peak Torque at RPM: 465@6500 Baseline hp/tq for a stock on same dyno: 08 STi = 240 hp Target Boost: 33 psi Target AFR: varies with boost Fuel: pump E85 Engine/Power Modifications: - Moore Performance World "street" twin-scroll header and Adaptor (stock-style JDM up-pipe to T4 rotated flange) - Borg Warner non EFR s300 twin-scroll turbo - 66mm. 82 lb/min compressor flow. - Twin Tial 38mm wastegates and 50mm BOV - Moore Performance full 4" v-banded downpipe - Moore Performance 3.5" downpipe-back exhaust - Moore Performance air-to-water oversized heat exchanger and 4 gallon ice reservoir - Moore Performance 2.5L non-sleeved shortblock - Manley rods and pistons, ACL bearings. 7.8:1 compression. - Moore Performance engine BlastPlates - block reinforcement/windage system - Killler B Motorsports reinforced oil pan pick-up - Perrin EBCS in dual port configuration - Moore Performance 25B heads - full CNC port, +1mm in/out valves, Moore-spec regrind. - Moore Performance sheet metal intake manifold with built in dual air-to-water intercoolers featuring Bell cores. Stock STi throttle body phased 90 degrees. - Grimmspeed 3mm phenolic spacers - Moore Performance Scavenger series catch can/evacuation system - Moore Performance -6 an parallel fuel rail kit with Fuel Injector Clinic 2100cc injectors, Aeromotive A1000 regulator - Moore Performance in-tank dual pump setup featuring Jay Racing Pro Series 342 pumps. - Green Filter USA 4" I.D. by 12" long conical filter. - Cobb Accessport v.2 in full speed density mode. Calibrated by Mike @ Innovative. Driveline Modifications: - Moore Performance transmission featuring 2002 Subaru WRX transmission case, Subaru 5 speed gearset, carrier for STi plug-in axles and metal speedo gear. - Moore Performance BlastPlates - transmission strengthening system. - Moore Performance Dragon's Blood transmission fluid. - Carbonetic triple carbon clutch and clutch-pack r180 rear differential. Other Modifications: - Moore Performance MooreCool Race Coolant in both the radiator and the air-to-water system. The Fozzy XTi has long been a testbed for all sorts of Moore-branded parts; we never know how certain combos are going to turn out until they go from paper to the dyno...but it's fun finding out! The goal this round was a mix of both low-end response and top-end power...all while funneling it through a Subaru 5 speed trans and a non-sleeved block. We're very happy with the results of the BlastPlates for the transmission that we've been offering for awhile now, not to mention the prototype of our new girdle/windage brace! We're also closer to a production-style intake manifold with this round of testing. Furthermore, we have some new tweaks to try out for our twin-scroll specific camshaft and CNC porting programs. All-in-all this is a solid-performing setup that, with a few modifications, has the potential for faster spool...even through there's still headroom in both compressor and turbine flow; I guess we'll see what happens next round. But until then, a big thanks to Mike @ Innovative Tuning for the stellar calibrations, Mike Vindler for his CAD/Forester-specific prowess and Jason Economu at Carbotron for the late night whiteboard sessions. Link to comment Share on other sites More sharing options...
Code Posted November 25, 2013 Share Posted November 25, 2013 Awesome build. Great shop. Great owner. Great experiences there every time I've needed something subie related. Congrats on a beast of a Foz. "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
loogie Posted November 25, 2013 Share Posted November 25, 2013 hot dogs! Link to comment Share on other sites More sharing options...
BrandonspecB Posted November 25, 2013 Share Posted November 25, 2013 Wow, I really like that torque curve. Link to comment Share on other sites More sharing options...
idiot4hire Posted January 6, 2014 Share Posted January 6, 2014 Innovative is a great shop. I like that they hold the quarter mile record for a stock block. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted January 6, 2014 Share Posted January 6, 2014 Wow just wow! Link to comment Share on other sites More sharing options...
INVNO1 Posted September 25, 2014 Share Posted September 25, 2014 How is the trans holding up with those blast plates? Sorry for the old thread revival Link to comment Share on other sites More sharing options...
jhawk222 Posted September 25, 2014 Share Posted September 25, 2014 ^^^I'm glad you breathed new life into the post.......that build is INCREDIBLE!! Link to comment Share on other sites More sharing options...
bettner12 Posted September 25, 2014 Author Share Posted September 25, 2014 How is the trans holding up with those blast plates? Sorry for the old thread revival trans held up great, bad news is we have short attention spans... [ame=http://www.youtube.com/watch?v=qnzezqXbaxg]2005 Moore Performance Forester XT Loud Exhaust - YouTube[/ame] best car to be watching with the blast plates is this one: 2009 WRX 751awhp/ 638 lbs tq STOCK TRANSMISSION! Link to comment Share on other sites More sharing options...
Code Posted September 26, 2014 Share Posted September 26, 2014 Is that car running a r160 rear diff? "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
bettner12 Posted September 26, 2014 Author Share Posted September 26, 2014 Is that car running a r160 rear diff? the Forester, or the wrx? Link to comment Share on other sites More sharing options...
Code Posted September 26, 2014 Share Posted September 26, 2014 Lol, both I guess. "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
INVNO1 Posted September 26, 2014 Share Posted September 26, 2014 trans held up great, bad news is we have short attention spans... best car to be watching with the blast plates is this one: 2009 WRX 751awhp/ 638 lbs tq STOCK TRANSMISSION! I've been checking that one too. I was more interested in someones more long-term results. Link to comment Share on other sites More sharing options...
bettner12 Posted October 9, 2014 Author Share Posted October 9, 2014 10.7 1/4 Mile on a 5 speed with blast plates http://forums.nasioc.com/forums/showthread.php?t=2671468 Link to comment Share on other sites More sharing options...
