deadsnake Posted December 9, 2013 Share Posted December 9, 2013 Hello there, I am trying to do a full brake job on my 05 legacy GT Limited ( I guess its limited, according to research if it has leather seats, power front seat, moon roof etc it makes it a limited). I found "CENTRIC" rotors for the rear on amazon, but when I try to search for any fronts, they all exclude the limited version... any thoughts? Notes: Front Premium Rotor, I - LIMITED (EXC GT LIMITED) is what I get when I search them. Centric Parts 120.47012 Premium Brake Rotor with E-Coating : Amazon.com : Automotive Centric Parts 120.47012 Premium Brake Rotor with E-Coating : Amazon.com : Automotive Will these work for the rears? Centric Parts 120.47025 Premium Brake Rotor with E-Coating : Amazon.com : Automotive Centric Parts 120.47025 Premium Brake Rotor with E-Coating : Amazon.com : Automotive Link to comment Share on other sites More sharing options...
KCwagon Posted December 9, 2013 Share Posted December 9, 2013 All the LGT brakes are the same 05-09, including Spec B, non-limited and Limited. I am not sure why they excluded limited in the fitment guide. Link to comment Share on other sites More sharing options...
deadsnake Posted December 9, 2013 Author Share Posted December 9, 2013 They say these are direct fitments for rears [ame=http://www.amazon.com/gp/product/B000IY4A3Q/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=ATVPDKIKX0DER]Centric Parts 120.47025 Premium Brake Rotor with E-Coating : Amazon.com : Automotive[/ame] But when I try fronts [ame=http://www.amazon.com/Centric-Parts-120-47012-Premium-E-Coating/dp/B000BZXR5Y/ref=au_pf_ss_6?ie=UTF8&Make=Subaru%7C13&Model=Legacy%7C64&Year=2005%7C2005&carId=002&n=15684181&s=automotive]Centric Parts 120.47012 Premium Brake Rotor with E-Coating : Amazon.com : Automotive[/ame] That is what I get, would they both work? What do you recommend for pads? Link to comment Share on other sites More sharing options...
legacy360 Posted December 10, 2013 Share Posted December 10, 2013 Look here, these are the proper part #'s for Centric. You can see the difference's between GT and 2.5i models. http://centriccatalog.com/Inquiry/AppResult.aspx?id=WEB_DISC&y=2005&m=13&mm=64 Link to comment Share on other sites More sharing options...
deadsnake Posted December 10, 2013 Author Share Posted December 10, 2013 Perfect thank you! Found both, now for pads, what do you recommend for daily use? Link to comment Share on other sites More sharing options...
jasejase Posted December 10, 2013 Share Posted December 10, 2013 On many applications, the stock rotors are a decent choice. I believe (IIRC), the napa gold's are reman'd oem parts. May be cheaper. Link to comment Share on other sites More sharing options...
deadsnake Posted December 10, 2013 Author Share Posted December 10, 2013 Set of 4 for centric will run me 180$, I am okay with that, I just need some pads now. Link to comment Share on other sites More sharing options...
jasejase Posted December 10, 2013 Share Posted December 10, 2013 yep! The aftermarkets are generally cheaper. Again OEm pads produce the least amount of dust (more or less). When I go with pads, I will likely go stoptech street performance Link to comment Share on other sites More sharing options...
deadsnake Posted December 10, 2013 Author Share Posted December 10, 2013 Those are a tad pricey, I was looking at these [ame=http://www.amazon.com/Akebono-ACT929-ProACT-Ultra-Premium-Ceramic/dp/B000CGP13I/ref=au_pf_ss_1?ie=UTF8&Make=Subaru%7C13&Model=Legacy%7C64&Year=2005%7C2005&carId=002&n=15684181&s=automotive]Amazon.com: Akebono ACT929 ProACT Ultra-Premium Ceramic Brake Pad Set: Automotive[/ame] But again why does it say excludes limited? Link to comment Share on other sites More sharing options...
bluesuby Posted December 10, 2013 Share Posted December 10, 2013 Those are a tad pricey, I was looking at these Amazon.com: Akebono ACT929 ProACT Ultra-Premium Ceramic Brake Pad Set: Automotive But again why does it say excludes limited? As previously stated, the "limited" car is mechanically the same as other GTs, save for electric seats, leather and sunroof. The difference between GTs and the i versions is that GTs have larger brakes. The Akebono ceramics are pretty good. Quiet, stop well enough, and wear well. With 60,000 on a set, there's enough pad to last me through the Winter and posibly until next Fall. Link to comment Share on other sites More sharing options...
deadsnake Posted December 10, 2013 Author Share Posted December 10, 2013 Ahh okay, so just ignore the fact that it says excludes GT limited? Link to comment Share on other sites More sharing options...
deadsnake Posted December 10, 2013 Author Share Posted December 10, 2013 I am just reading so much conflicting info from all these parts stores. I don't even know whats what with the pads! Link to comment Share on other sites More sharing options...
jasejase Posted December 10, 2013 Share Posted December 10, 2013 Those are a tad pricey, I was looking at these Amazon.com: Akebono ACT929 ProACT Ultra-Premium Ceramic Brake Pad Set: Automotive But again why does it say excludes limited? Those are for non-turbo. All the reviews say 2.5i, outback, etc.. .No LGT. Link to comment Share on other sites More sharing options...
jasejase Posted December 10, 2013 Share Posted December 10, 2013 There is a 2.5i limited, and a 2.5gt limited. The 'limited package' is a trim package for both, adding no performance parts. You need brakes that fit a 05-09 Legacy GT (doesn't matter if its a limited package, spec.b, or regular GT) Link to comment Share on other sites More sharing options...
jasejase Posted December 10, 2013 Share Posted December 10, 2013 There is a 2.5i limited, and a 2.5gt limited. The 'limited package' is a trim package for both, adding no performance parts. You need brakes that fit a 05-09 Legacy GT (doesn't matter if its a limited package, spec.b, or regular GT) Email AZP installs or Infamous Parts/Performance Link to comment Share on other sites More sharing options...
AZP Installs Posted January 1, 2014 Share Posted January 1, 2014 Perhaps the folks at Amazon who sold you the rotors could help out? We sell the rotors and pads you need, let us know and we can definitely get a set out to you. Our suggestion is Stoptech Street Performance pads with Centric Premium Rotors. $285 + Shipping for both front and rear. -Mike Paisan http://www.pbase.com/paisan/image/153798190.jpg Maintaining, Modifying and Educating TriState Enthusiasts since 2001. Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs "Race Tested, Enthusiast Approved!" Link to comment Share on other sites More sharing options...
