berkshire40 Posted January 6, 2011 Share Posted January 6, 2011 I am looking for opinions regarding the amount of torque the OEM Spec.B clutch can handle. For my 16G setup if I did fuel mods I don't think the output would exceed around 350ft/lbs to the wheels? It's difficult to predict but I'm just trying to gauge about how long it will last with this future setup: -BNR EVO16G -IPR TMIC Coated -DW850cc + pump -CNT Catted DP 3" flange -Stromung exhaust 3" flange -Stock air box with AVO filter Car has under 15k miles. I emailed my tuner (Infamous1) but it would be great to get feedback from other SpecB owners as well. TIA Mod list & photos _ Link to comment Share on other sites More sharing options...
m sprank Posted January 6, 2011 Share Posted January 6, 2011 Clutch will hold to around 300-315whp. Then it will slip at WOT and peak torque. Mine did with just 15k on the clutch (most of that freeway commuting). Link to comment Share on other sites More sharing options...
rock2534 Posted January 7, 2011 Share Posted January 7, 2011 I have to replace my clutch...I noticed it started slipping under hard acceleration(not launches) from a dig about a year ago, but other than that it worked fine. I just recently went stage 2 and after a week or so it started slipping under wot around 2800rpm, tach would jump up to 4k. I have about 37k miles on the car, instead of going with another oem I got one from sprank. I still have the stock turbo, so with your setup I would think it will start slipping soon. Link to comment Share on other sites More sharing options...
wpmarky Posted January 7, 2011 Share Posted January 7, 2011 From what I researched, our clutch isn't much stronger than a 5mt clutch, though we do benefit from the single mass flywheel. Based on that, I figured 300/315 is as much as the stock clutch can take before slipping. You'll probly be ok for now, but will accelerate the wear on the stock clutch. I replaced my clutch before going stage 3, since I wanted to make sure there's no slipping during the tune. I've seen a few threads where some folks went stage 3 but were complaining about only being 270whp or 290whp. Then when someone asked what clutch they were running, there came the face palm moment. Link to comment Share on other sites More sharing options...
